Motorcycle Jack - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 20 Old 03-24-2014, 12:14 AM Thread Starter
Motorcycle Jack
I went out and bought a motorcycle jack in hopes of using it to jack the bike up so that I can change the rear shock. I didn't know that there wasn't much of a frame under this bike . Have any of you used a motorcycle jack on your bikes.??
kparkfan is offline
post #2 of 20 Old 03-24-2014, 10:04 AM
cpd419's Avatar
Just sold one for that reason. Wont work on these bikes as they are designed. I use swingarm spools off ebay for less than ten bucks and a rear stand. If you have a way to ratchet it up from above and a swingarm stand you should be golden.
cpd419 is offline
post #3 of 20 Old 03-24-2014, 10:34 AM
I used a motorcycle jack on the skid plate to adjust my chain. The person that sold me my bike said he had jacked it up that way many times. Is this a good idea or not?
keithert is offline
post #4 of 20 Old 03-24-2014, 11:40 AM
cpd419's Avatar
As long as the skid plate and mounting points are durable enough to support the weight I would use it.
cpd419 is offline
post #5 of 20 Old 03-24-2014, 06:16 PM
DougInKY's Avatar
Send a message via AIM to DougInKY Send a message via Skype™ to DougInKY
I bought a motorcycle jack adapter from someone in VSRI. He makes them. I just can't remember who. Maybe someone will come in and post the vendor (Dan somebody, also called Cherdan), in the meantime I will try to remember who makes them. The adapter he makes lifts the bike (along with using a motorcycle lift) from the hard points that Suzuki puts there for lifting.
Namaste'
Doug from Kentucky
2007 Wee-Strom (*SOLD*)
2009 Suzuki Burgman 650 Executive
1980 Honda Express (my toy!)
DougInKY is offline
post #6 of 20 Old 03-24-2014, 06:21 PM
DougInKY's Avatar
Okay, Van Vesel is the name. Here is a link to his stuff on Vstom Riders International: My V-Strom Accessories - Dan Vesel
I don't see his lift adapter anymore listed in his stuff. He does list his phone number though and if you contact him he might make one for you.
Namaste'
Doug from Kentucky
DougInKY is offline
post #7 of 20 Old 03-24-2014, 08:41 PM
bwringer's Avatar
I don't remember if you have one, but an aftermarket skid plate will support the bike, no problem. The stock plastic simulated skid plate, no.
At home, I use this rear stand with spools in the swingarm -- this is one of the best I've seen. I also have their front stand, but usually it's easier to just jack up under my skid plate:
URRS05-Adjustable Rear Stand
On the road, I carry an Endurostar trail stand:
Enduro Star / Trail Stand
Yes, it's plenty strong, and works great on the Vee.
bwringer is offline
post #8 of 20 Old 03-24-2014, 09:33 PM
griffondude's Avatar
Yes. I like the jack for long term winter maintenance. I wish I took a picture, but sadly, no. I inserted a long spike (14" nail, I think, through the hole located at the bottom of the engine. I then modified some 2X4s to pick up the bike by the spike. It took a bit of puzzling and I cut some grooves in the 2X4s for stability but it works, just. I then strap the bike to the jack for safety and leave it like that all winter.
https://www.stromtrooper.com/dl650-20...g-up-bike.html
Not my photos but I do it just like LucasD in that thread.
You can't change the oil or anything like that and if you have a skid plate, it probably needs to come off. It's great for major work like removing both wheels or disassembling the front or rear end completely. I like that I can lift it waaaay up to work on the valves comfortably.
On the road or to do chain maintenance? I use a 2X2 with a smaller chunk nailed to the side of it to do, effectively and free of charge, this:
Home made trail jack stand/forward foot rest - Kawasaki KLR 650 Forum
Have fun!
1980's-XL80s
1983 Nighthawk 550
1990's Vulcan 750
1983 GS450L
2004 DL650
There are still faint glimmers of civilization left in this barbaric slaughterhouse that was once known as humanity... Most of them ride V-Stroms.
griffondude is offline
post #9 of 20 Old 03-24-2014, 10:23 PM
Moderator
Rudderfeet's Avatar
I spent a couple hours one weekend trying to make a motorcycle jack adapter out of wood blocks. I got close but had to move on to other chores before I sealed the deal. The biggest challenge I ran into was not making the adapter so tall that the jack wouldn't fit under it. With proper time, I'm sure it could be done though.
2019 KTM 790 Adv R, 2013 Beta 350RR, 1991 XR250L
Rudderfeet is offline
post #10 of 20 Old 03-25-2014, 04:55 AM Thread Starter
I have a paddock stand for the bike. Didn't know if thats all I needed to do the shock change. Got all the goodies in now to change it all over to Progressive. :mrgreen:
kparkfan is offline
