Need suspension done but have no idea where to start - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 18 Old 02-05-2014, 01:01 AM Thread Starter
I must admit I have been spoiled owning my BMW GSA's in the past with the electronic suspension. Changing setting at the push of a button. Well I'm 250lbs and in need of some suspension work I would suppose. I figure at my weight the stock ones are not correct. This is my deal. I have no idea myself how to setup suspension, how to remove it or to send to someone or anything like that. I'm sure I could figure out how to take it out but once I get it out who's the recommended place to send it to get it set up right? I've been trying to go thought some of these suspension threads over the past year but it seems like most guys are DIY guys. Isn't there someone out there that can just do it all for me? There's no way I'm gonna trust myself to change fork springs etc. Where would you go and what's it gonna set me back to have it done? And will I even notice a difference. Is it really that critical?
lacofdfireman is offline
post #2 of 18 Old 02-05-2014, 07:51 AM
Fork springs are no problem, I put Sonic springs in mine and it was much better, I weigh close to what you do. The shock is another story, I want to put a heavier spring on mine as it is maxed out on preload.
K7 DL650 The fast grey one
Spikester is offline
post #3 of 18 Old 02-05-2014, 08:19 AM
om28's Avatar
It sounds like you need to find a local suspension shop where you can ride the bike in and they'll take the suspension off, respring/revalve the forks and shock. If there's no local shop there's few companies that you can send your forks and shock to and have rebuilt for your weight and riding style, such as Race Tech, Cogent, and Daugherty Motorsports. But if you're not a DIYer you'll need to take the bike to the dealer to have the suspension taken off and sent out. If you're going to do this it might be better to buy a rear shock and fork internals and have the dealer just install them. This might be the easiest solution, research aftermarket shocks and pick one, research fork options, most likely a heavier spring for your weight, and possibly a cartridge emulator such as Race Tech, Ricor, or Cogent. Take your bike along, with your new upgrades, to the dealer and they can put them on in a day.
2009 Wee Strom ABS (current)
1987 Harley Low Rider Sport (current - with 205K miles)
2009 Aprilia Mana 850, 2006 SV650, 1984 Yamaha Virago 1000 (all sold)
Silver Strom Club Member #11
Wee Farkles: Russell Day Long Seat, Madstad with Moose Adventure Shield +4'', SWMotech Centerstand, 1'' up & back bar risers, Givi XS308 Tankbag, Aprilia mirrors, Framesliders, Fenda Extenda, Elka Shock.
om28 is offline
post #4 of 18 Old 02-05-2014, 08:45 AM
The rear shock is a simple bolt in process. Ordering the correct one is fairly easy, you do need to talk to someone about what you need to get the right spring and valving.
The front is actually easier than most think. Not sure what V Strom you have, just springs and oil in a 1000 helps a lot. Springs, oil, and cartridge emulators are the way to go in a 650.
Any competent motorcycle shop can do this for you.
realshelby is offline
post #5 of 18 Old 02-05-2014, 08:47 AM
cameraman's Avatar
Yes, you will notice a difference and its well worth it! The factory suspension is set up for Jockeys (165-175lbs rider), not real humans. I weigh 220 and just added 1.0 Sonic Springs in the forks. Very nice and well worth it. Now when I am riding off pavement and hit a hole or a rock it doesn't knock my teeth out. Nose diving under braking is also reduced. I have an Elka rear suspension but the spring there needs to be stiffer and I have plans to swap that out as well. But even with the lighter spring, its massively improved over stock.
Now to the DIY part. I am by no means a mechanic, but swapping out the springs was really simple. It just takes patience taking the front end apart and putting it back together (that's harder than actually disassembling/assembling the forks.. BlackLab has a very detailed "how to" written up and made it a very easy project. But the motorcycle is a toy for me, something to learn on. So I don't have a problem taking a crack at working on it. I have riding buddies and google that can lend a hand to damn near do anything on the bike.
Tom G
Atlana
07' weeeeee!!!
cameraman is offline
post #6 of 18 Old 02-05-2014, 11:10 AM
lacofdfireman, do you have a local shop you trust? They can do the work with parts you get from elsewhere.
Rich Desmond's Sonic Springs are a good choice for the front. You can contact Rich for suspension advice, and he rides a V-Strom. SonicSprings.com
Cogent Dynamics has a drop-in damping valve for the forks. They can also re-spring your shock, as can many local shops. Drop in Damper Cartridge (DDC)
Blair Layton at svracingparts offers the excellent complete Elka shock.
SV Racing Parts | Store
Richland Rick makes fork braces and other parts he makes that help improve the bike and make the bike fit the rider. http://www.adventuretech.biz/
There is a lot of overlap from these vendors. Rich has front springs and great advice. Blair has front springs, RaceTech front damping valves, and the Elka shock, along with good advice. Cogent offers everything as well. Spread the wealth or go with one--you'll like the result.
post #7 of 18 Old 02-05-2014, 12:04 PM
Swapping the front and back springs isn't too involved if you have the tools, a shop manual and courage. Well worth the effort but not up to GSA standards.
06 DL1000
2007 Royal Star Tour Deluxe
Illinois is offline
post #8 of 18 Old 02-05-2014, 02:24 PM Thread Starter
Ok thanks for the replies. So just give it to me straight up. What's the good setup if I have say $1500 to spend. I't looks like I can at least take everything off but I would probably pay someone to do the labor on the Front forks. I would take the front forks to them but just have them install whatever I buy. So what would you go with. I figure I weight 250, wife 125 then luggage another 30-50 so we are talking 425lbs all in with gear. I have no idea what emulators are vs. springs. Do I need both? I figure the rear shock is basic. I just order the correct one and replace stock and reinstall new one. The forks seem a little more involved though. That's why I would pay to have those done, so they are done right. Hoping to get this all done before the Tour of California in May. I wanna be set up right..
post #9 of 18 Old 02-05-2014, 04:55 PM
We want to fix two things...get front and rear springs that suit our loaded riding weight, and perhaps improve the damping of the front dampers (forks) and rear damper (shock). Just getting the springs right is the first job.
Front spring rate calculator
SonicSprings.com
RaceTech cartridge emulators are one type of improved damping valve to make the forks react more accurately when you cross a bump. Others are the Cogent Dynamics Drop In Damper Cartridge and the Ricor Intiminator. I think the RaceTech unit requires more disassembly and work on the forks, and the Intiminator might take more trials and changes to get to your liking (although I think they changed the setting since I bought mine).
So...from my experience I know that Blair at Svracingparts and Rich Desmond at Sonic Springs are very good guys to work with, as well as Richland Rick for the fork brace--all ride Stroms. We've heard good things about the owner of Cogent Dynamics, but we don't know what he rides. Try emailing or telephoning these guys, tell them your situation, and get their advice, prices, and availability of parts. Me...I'd get the front springs from Rich, front damper valve cartridge from Cogent, Elka shock from Blair (or the stock shock reworked by Cogent), and fork brace from Rick. There is nothing wrong with getting everything from one source. Your local shop can give you prices for their work; it shouldn't be a lot.
post #10 of 18 Old 02-05-2014, 04:58 PM
om28's Avatar
There's many answers to this one, and I'm sure you're going to hear them. It sounds like you want something simple, that doesn't require a lot of tweaking, and also performs well.
FORKS: I'd say start with a set of Sonic springs for your weight, they have a calculator on their site, the link is above. You can always upgrade to an emulator later if need more performance. I'd go with Ricor or Cogent since they install easily, rather than Race Tech which require a little more modifying. Springs are roughly $100, emulators around $175.
SHOCK: Something custom made for your weight and riding style, they don't really cost anymore than an off the shelf shock, such as a Progressive. Since you carry a passenger it should have a remote preload. Elka is very popular, they are completely adjustable (lots of knobs to twist), great bang for the buck, you can get them through sv racing about $1000, link above. If you don't want to twist knobs Cogent, Ricor, and others custom make shocks with less adjustability for around $600 to $700.
If you want a good, simple package call Cogent and get their front fork kit and shock, both made for you for probably under $1000....done.
Lots of options here.
om28 is offline
