06 V - are stock fork spring progressive rate? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 01-28-2014, 10:59 PM Thread Starter
KTM Mike's Avatar
As the title says - on a 2006 DL1000, are stock fork springs progressive rate springs? Ive found specific mention that the 650's are - but have not found mention that the 1000's are.
Reason I am asking is that I stumbled across a thread here where a 650 owner cut off some of the tight wound coils to increase spring rate - with great sucess This prompted my grey matter to remember many years back (1994) I was setting up a Kawasaki Concours with a sidecar - and had a Works Performance shock custom built for me - their engineer Sandy suggested I simply cut coils on my progressive (brand) springs I had to bring their rate up - which worked fantastic.
So....its a low/no cost option to increase spring rate vs buying new springs..IF the 1000's are progressive rate springs stock!
No longer a Vstrom Owner - fantastic bike! Now sporting a KTM 990 Adventure
KTM Mike is offline
post #2 of 6 Old 01-28-2014, 11:34 PM
kiwi_outdoors's Avatar
aftermaket springs are cheap
aftermarket springs are cheap. like $74 for me Wee.
Current Bike: 2007 ABS Wee, rebuilt forks with Cogent DDC, Elka rear shock, tapered roller steering stem bearings, fork brace, Admore top box lights, LED side-only turn indicator lights, Powerlet outlet, frame sliders, Givi windscreen, Givi top box.
Prior Bikes: 2003 EX250, 2007 DL650 (non-ABS)
kiwi_outdoors is offline
post #3 of 6 Old 01-29-2014, 12:06 AM
https://www.stromtrooper.com/v-strom-...k-springs.html
post #4 of 6 Old 01-29-2014, 06:27 PM Thread Starter
KTM Mike's Avatar
My question was not what the cost to buy new was - I have already researched that. If I were to buy new, it would go with the Sonic springs most likely.
Yes - cut my fork springs. I have already researched that AND had great success on my Concours years ago. 50,000 miles tugging a sidecar rig around with the wife and kid on board should be a reasonable test ride. Right here on Stromtroopers is a very well done write up on doing exactly that WITH a professional suspension tuner having put the springs on a dyno to verify rate impact.
Back to my original question:
Does my 2006 V have progressive wound springs stock? The 650 does. I am simply trying to verify what the 1000 has.
KTM Mike is offline
post #5 of 6 Old 01-29-2014, 07:07 PM Thread Starter
KTM Mike's Avatar
And here is a link to the post here on doing exactly what I plan to do (once I can confirm my 1000 indeed has progressive springs.) I would just pop out to the garage and check myself, but below zero temps make that rather unattractive!
https://www.stromtrooper.com/dl650-20...ead-first.html
and keep in mind, way back when I did this on my Concours, I did it based on the recommendation of a suspension engineer at Works Performance. Its not a unsubstantiated garage hack job.
KTM Mike is offline
post #6 of 6 Old 01-29-2014, 07:10 PM
Cutting springs and replacing the cut length with a spacer increases the effective spring rate whether the springs are progressive or not. I'm pretty sure both Wee and Vee have dual rate springs rather than true progressives.
