Front Fork Mod 05 DL650 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 01-22-2014, 06:02 PM Thread Starter
joethebike's Avatar
A friend, Blair Harley, shared my dissatisfaction with small bump compliance from the front of his (07) DL650 and replaced the steel spacer above the springs with a specially wound helper spring the same length as the steel spacer.
Version 1 which he gave to me used a short spring with plastic spacer while Version 2 used on his bike (subsequently totalled by an inattentive driver) was a full length spring.
Blair said the full length spring worked even better than Version 1.
Even so the short spring and spacer markedly improves compliance on my 05 and sag height before and after installation was unchanged.
joethebike is offline
post #2 of 4 Old 01-23-2014, 07:53 AM
Your probably making the spring rate softer by basically putting in a longer spring than stock.
K7 DL650 The fast grey one
Spikester is offline
post #3 of 4 Old 01-23-2014, 07:57 AM
om28's Avatar
Interesting. Works Performance does this with their shocks, they stack one spring on top of another. I'm not sure about the math, but the 2 springs are softer than either spring by itself. When the smaller spring fully compresses the larger spring takes over with it's higher rate, so you get a dual rate suspension, similar to a progressive spring but with a defined line where the rate changes. WP uses spacers to allow you to preload the small spring to adjust the rate change over point. By not using a spacer your friends Version 2 rate change came later in the stroke than your Version 1.
2009 Wee Strom ABS (current)
1987 Harley Low Rider Sport (current - with 205K miles)
2009 Aprilia Mana 850, 2006 SV650, 1984 Yamaha Virago 1000 (all sold)
Silver Strom Club Member #11
Wee Farkles: Russell Day Long Seat, Madstad with Moose Adventure Shield +4'', SWMotech Centerstand, 1'' up & back bar risers, Givi XS308 Tankbag, Aprilia mirrors, Framesliders, Fenda Extenda, Elka Shock.
om28 is offline
post #4 of 4 Old 01-24-2014, 02:01 AM
Blair is an old Maico man, thats what maicos did.
RowBust is offline
