Torque Specs - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 10 Old 01-02-2014, 11:30 PM Thread Starter
Eyball's Avatar
Torque Specs
I know I'm being lazy but I'm tight on time, can anyone give me the torque specs for the front & rear axles on 07 1000. Also the sinch bolts for front?
Thanks!!
Eyball is offline
post #2 of 10 Old 01-02-2014, 11:42 PM
100nm for the axles and 23nm for the pinch bolts.
JustSaying is offline
post #3 of 10 Old 01-03-2014, 12:00 AM Thread Starter
Eyball's Avatar
Thanks man! You just use a little general purpose grease too?
Eyball is offline
post #4 of 10 Old 01-03-2014, 12:12 AM
https://www.stromtrooper.com/general-...ad-galled.html
post #5 of 10 Old 01-03-2014, 12:29 AM Thread Starter
Eyball's Avatar
My axles are in great shape, just waiting for tires to come in tomorrow. & reassemble. Thanks for the help. getting rid of the shinkos and getting some Michelins
Eyball is offline
post #6 of 10 Old 01-03-2014, 02:30 AM
The manual doesn't call for any anti-seize or grease at those torque values.
post #7 of 10 Old 01-03-2014, 08:20 AM
https://www.stromtrooper.com/general-...tatements.html
post #8 of 10 Old 01-03-2014, 01:11 PM Thread Starter
Eyball's Avatar
So I should not grease the axel? It had a light coating if grease when I pulled it off the bike. Thanks
Eyball is offline
post #9 of 10 Old 01-03-2014, 01:17 PM
That's okay if you choose. It will insure the axle stays free of the bearings but that shouldn't happen because the axle is stainless steel and won't deeply corrode. The important part is to use anti seize on the axle threads to prevent galling between the axle and axle nut and reduce the torque to 58lb-ft to account for the lubrication effect.
post #10 of 10 Old 01-03-2014, 01:34 PM Thread Starter
Eyball's Avatar
Thanks for the help. I appreciate it!
Eyball is offline
