Shinko 712 Report - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
post #1 of 24 Old 09-01-2013, 06:29 PM Thread Starter
Shinko 712 Report
In the middle of May this year my new-to-me '08 Wee needed some new tires. It still had the original factory ones and they were at 11K miles with still a whiff of tread left, but not much. Not being made of money, and hearing about impending furloughs for Federal employees, I really couldn't afford to spend a lot so I started looking around. My other bike (don't own a car!) is an '05 GS with 80K miles and I usually run Shinko 705s on it (I get between 6-8K miles on the rear and 12-15K on the front) but even the price of them was too much so I kept looking. The adventure bike sizes of 110\80-19 and 150\70-17 are well served in the marketplace with many high-end brands with commensurate high-end prices. I started searching various sites by size instead of type and hit on the Shinko 712s. They are made for some Harley so I thought on the Wee they would last a good while. Whereas the tread pattern is strictly street, so is 98% of my riding, so that was no problem. The only hitch was the front size. It didn't come in the 110\80-19. You have a choice of: 110\90-19 or 100\90-19. Because the speedo and odo are driven by the front tire I wanted it to be very close to stock. I found a site that gave the circumference for all three sizes and the 100\90-19 was a tiny bit different from the stock 110\80-19 (about 1%) so I went with it. When I installed them they went on as easy as the 705's usually do and the front looks just the same as the original to the eye. The speedo registers the same by my gps as the old tires did and my fuel mileage is identical so the odo is very close too.
I've ridden them for over 7K miles now and the front still looks new. The rear shows a little wear, but not much. I expect to get at least 10-12K on it.
The best part was the cost. I sourced them from Motorcycle Superstore and they were: front $48.99 and rear $67.99 shipped to my door. That comes to $116.98 for both tires!
I use my bike for commuting (50 miles RT) and weekend travel (~200 miles each weekend) and they handle everything I've been in from torrential Florida rains to egg-frying-hot asphalt and I've been very pleased with the results.
dechaoz05 likes this.
John Greenwood
Jacksonville, Florida
'05 BMW R1200GS
'12 V-Strom DL650A
Secret Buzzard is offline
post #2 of 24 Old 09-01-2013, 08:06 PM
Our dreams are made of such reports after spending twice that on just a rear tire.
I'll be mounting Shinkos in the future.
post #3 of 24 Old 09-01-2013, 08:14 PM
vegashotwheeler's Avatar
Send a message via AIM to vegashotwheeler
Havent seen the 712.
But on my second rear 705 and Im happy for what they are.
Its not like the Conti trail attacks I liked but fit my budget much better.
Mike
2007 Blue DL650 V-Strom - running out of farkle's to do so bought the VEE
2006 SILVER DL1000 - Running out of Farkles also!!!
2017 EX300 Kawasaki Ninja
Las Vegas, NV
vegashotwheeler is offline
post #4 of 24 Old 09-24-2013, 11:04 AM
I think I will try the 712 after my fresh 705s die. It has a lot of fans on many different bikes with few complaints. I'll be watching long term reports. $120 for 2 good tires is as good as it gets.
arty-up is offline
post #5 of 24 Old 11-24-2013, 12:33 PM
J_Bone's Avatar
Any updates? IF this tire is half way descent, I'm game. I ride mostly freeway for my 100 mile commute, so a street tire isn't a bad idea.
J_Bone is offline
post #6 of 24 Old 01-01-2014, 11:19 PM Thread Starter
I replaced the rear with another 712 after putting 11,800 miles on it. I was slightly into the wear bars, but no cords showing. The front still appears new. I've started using them on my GS as well because I never go off road.
John Greenwood
'05 BMW R1200GS
'12 V-Strom DL650A
post #7 of 24 Old 01-02-2014, 01:13 AM
T-ville Trooper's Avatar
When I started riding the wee ! could get 11000 or 12000 out of a front tire and about 2/3 of that on a rear.
I did 10000 miles this year and burned through two sets of tires. (Metlers)
and they are wearing out at the same rate front to rear.
I never wanted to try a Shinko because I have read that they wear out fast.
How are you getting that many miles out of them?
T-ville
T-ville Trooper is offline
post #8 of 24 Old 01-02-2014, 09:11 AM
congratulations
Faster riding results in reduced tire life.
richw is offline
post #9 of 24 Old 02-14-2014, 07:53 PM
Looking to go to a street tire for an upcoming ride that will end up being about 3500 miles or so but no dirt. Thinking this may be a good choice? Someone said on another site that they do not make the correct size for the 07 VStrom 650 is this correct? If so what size are you running on the Wee?
lacofdfireman is offline
post #10 of 24 Old 02-14-2014, 08:14 PM
bwringer's Avatar
He's using the 712, which is a pure street tire.
You're probably thinking of the 705, which is a dual-sport tire.
As noted above, the proper size for the front (110/80-19) is not available in the 712, but a 100/90-19 seems to work just fine for the OP.
bwringer is offline
