SV1000 wheels on a Vee? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 10 Old 08-06-2013, 09:40 PM Thread Starter
do someone know if I can use SV1000 wheels on my DL1000? I'd use them for street tires, 17" front and rear. thanks !
03 DL1000
PCIII USB
Givi E52/E360 cases
Sargeant seat
Enduro Guardian skidplate
Givi crashbar
Adventure Tech fork brace
Progressive suspension fork spring
Racetech Gold Valve G2R
Elka rear shock
Madstad Robobracket windshield
Flat4awd is offline
post #2 of 10 Old 08-07-2013, 01:29 AM
PiJiL's Avatar
Rear rim won't fit but the front will :-)
Just make sure you measure the front disc inner and outer diameter...
PiJiL is offline
post #3 of 10 Old 02-24-2014, 09:08 AM
SV1000 rear will fit the DL1000 w/ some blacksmithing - it's not the easiest swap but it seems to be doable by mere mortals. I'm working out the details of the SV1000 rear caliper bracket alterations right now. I'll post some pics when it's done, assuming that I don't hit any last-minute show-stoppers.
I'm also grafting a GSXR600 front wheel to the front end so I'll post those pics as well.
There's lots of good information over on the Vstrom dot info website if you're curious.
"Making bad choices since 1948...."[LEFT][SIGPIC][/SIGPIC][/LEFT]
Leroy is offline
post #4 of 10 Old 03-15-2014, 03:45 PM
Don't have a tire on it yet but here it is -
This, unfortunately, is as far as I've gotten on the front. Once the weather warms up enough to paint the wheel black the rest of the work should go pretty quickly.
Leroy is offline
post #5 of 10 Old 03-19-2014, 05:38 PM
Fat City
Look what the Brown Goodie Truck dropped onto the front porch this afternoon -
A pair of Pirelli Night Dragons. Pirelli appears to be the only manufacturer other than Dunlop that makes a cruiser tire in 180/xx-17. I bought the bias belted version with an 81 load rating so I'm hoping that it delivers the mileage. If it doesn't then look out darkside, here I come.
The carcass on the rear, by the way, is as stiff as a semi-tractor tire. Mounting will be interesting....
Leroy is offline
post #6 of 10 Old 03-21-2014, 02:51 PM
No Drama
Mounting the stiff-walled rear cruiser tire was less interesting than I thought it might be. No muscle pulls, cuts or smashed knuckles - life is good... for this afternoon anyway. :mrgreen:
The stars of the show were the No-Scuff tire bar, the long tire iron (for the last few inches of bead) and Ru-Glyde. The Moose Racing tire stand is bolted to the floor, which makes all of this work.
Leroy is offline
post #7 of 10 Old 04-02-2014, 05:58 PM
Here they are boys & girls - all done except for trimming the front fender to accommodate the fat front tire. I sawed out the extraneous aluminum from the rear rotor spacer to make things look a little tidier - OCD runs in the family.
I had some serious sticker shock with the 3 new rotors but I'd rather spend the money on myself than leave it to the kids - I'm that kind of guy.
Leroy is offline
post #8 of 10 Old 04-02-2014, 07:16 PM
Good work!!!!!
post #9 of 10 Old 04-03-2014, 08:12 AM
Thanks. I've been pretty long-winded about this project but I felt that Flat4awd deserved an answer to his question. Once I get the wheels on the bike and scuff in the tires I'll post some final pics and tie this off.
Edit - At day's end....
In the mean time, here's where we are by Thursday evening -
Even after trimming the front fender it still reminds me of the Rick Moranis character Dark Helmet in the Mel Brooks comedy "Spaceballs."
Nothing to do now but go for a ride... if it ever stops raining.
Leroy is offline
post #10 of 10 Old 04-05-2014, 12:56 PM
OK, last post - scout's honor. I took the bike out for a brief test with a cruiser-riding friend this morning. No handling quirks were noted other than a slightly slower response to counter-steering maneuvers, possibly because of the greater rotating mass of that big old cruiser tire on the front rim.
I'm pleased with the outcome. The bike is eerily smooth, maybe because I took the time while everything was apart to sort through the spacer issues to get both the sprockets and wheels aligned. Now to see if the tire choice delivers the hoped-for mileage.
Leroy is offline
