Brazilian Metzeler 880 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 06-18-2013, 09:26 AM Thread Starter
I did a search on this before posting, nothing found.
I just mounted a Metzeler Marathon 880 160/70/B17 73h (made in Brazil, very recent mfg. date) on the back of my '07 650A. Inflated to 42 psi. When slowing to a stop (from about 17 mph to around 13 mph) I'm feeling a slight vibration.
I removed the rear wheel, double checked everything (balance, spacers, hardware, etc.) and found nothing amiss. Remounted wheel on bike, same vibration when slowing to a stop. I've only put about 20 miles on the bike since mounting the tire and the vibration is very slight.
I've read a few posts on other sites about issues with Brazilian-made Metzelers. Anyone have an issue with these?
nonmilagno is offline
post #2 of 4 Old 06-18-2013, 07:55 PM
On my 3rd 880 ( rear) and nothing like this has come up. Did you remove the brake caliper during the process ?
14 DL650 Adventure
07 DL1000 ( Sold )
05 KLR 650 ( Sold )
01 Vulcan 1500 ( Sold )
55 CJ5
slaghammer is offline
post #3 of 4 Old 06-18-2013, 09:58 PM Thread Starter
Yes, I removed the caliper and tie-wrapped it to the swing arm while changing the tire. I made sure the caliper was aligned correctly during re-installation. Also, checked chain tension and alignment carefully. After the ride the tire did seem pretty hot (very hot day) but the brake disc and sprocket seemed normal.
post #4 of 4 Old 08-08-2013, 12:20 AM
Newstrom48's Avatar
Have had 2 of these tires and never had anything as you described.
Newstrom48
2009 DL1000
Too many Farkles
Newstrom48 is offline
