Quick-n-Dirty TEMPORARY spring change: is it OK? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 05-02-2013, 08:25 PM Thread Starter
Hi All---I just got some Sonic Springs for my Wee and am dying to try them out (partly because the wife and I are doing a long 2-up ride this weekend). I don't have time for a full, proper fork removal/cleaning/spring change/reinstallation...
...so I'm wondering, is there any reason why a quick-n-dirty spring change (hold the front end up, remove the fork caps, carefully pull out the old springs letting as much oil drain off them as possible back into the tubes, put the Sonic Springs in, put the new spacers in, put the caps back on) would be a terribly bad or dangerous thing to do?
I figure I could do this in 30-40mins tonight (we leave tomorrow morning)...and that would at least let us *try* the Sonic Springs for our ride. Then I could (and would) do a proper fork removal change next week.
Thanks for the advice!
Scott
SWriverstone is offline
post #2 of 3 Old 05-02-2013, 09:04 PM
Downs's Avatar
Shouldn't be a big issue. You'll just have dirty fork oil in there.
Downs is offline
post #3 of 3 Old 05-03-2013, 12:07 AM
Do one side at a time and the other side holds the bike up.
Try reusing the stock spacers and see if you can get the recommended 40 mm sag. It worked for me. Front sag stays the same one or two up. Set the rear sag at 40 mm one up, and probably crank the adjuster all the way up for two up.
