Dumb real axle flip question - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 04-15-2013, 02:06 PM Thread Starter
O.K. this may not be the correct place for this question but I will try anyway.
I recently removed/re-installed my rear wheel after having someone else (Cycle Gear) actually put the new tire on the wheel.
Here's the problem. When I put the new tire on I flipped the axle end-to-end as recommended by a lot of V-Strom'ers, which worked much better. The problem is that, when I installed the axle/wheel I had to loosen the chain adjustment bolts on both sides just to get the axle in. And even after loosening it about 1 full turn, the chain is tight. Like much tighter than it was before I started.
This make no sense at all to me. Why would the adjustment change when replacing a tire? Any chance I totally screwed the pooch on this?
Thanks in advance.
Kevan "Wretch with a wrench" Garrett
Kevan Garrett is offline
post #2 of 4 Old 04-15-2013, 02:47 PM
One turn is not much. Just back off the adjusters and redo the adjustment. You need a good inch of slack at the tightest point when measured on the side stand. I don't know why that would happen but I wouldn't worry.
post #3 of 4 Old 04-15-2013, 04:17 PM
I've never had luck just backing off the adjusters to where I could get the axle out and then back in. I end up loosening the adjusters a lot and then tightening again after I have the axle in and nut on and get rid of some the slack. It's a bit fiddley but not difficult.
The only screwed pooch to worry about is not getting the caliper into the slide properly and having it catch and flip.
post #4 of 4 Old 04-15-2013, 04:23 PM
tmcgee's Avatar
Yeah, you've got to back the adjusters off quite a bit. As to backwards axles, it doesn't make it easier for all of us. Securing the brake caliper is a much bigger help for me.
tmcgee is offline
