how do I use the quote button? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Rules, Forum Support, Help and Information [NOT FOR MOTORCYCLE RELATED QUESTIONS] Please read the rules before posting. Need help with this forum and it's functions? Post your concern in the relevant category for the volunteer moderators to assist you. [NOT for motorcycle related questions!]
post #1 of 5 Old 09-16-2012, 08:01 AM Thread Starter
I have looked for some instructions for using the quote button and can't find any.Is there a post regarding this?Thanks
mark2wheeler is offline
post #2 of 5 Old 09-16-2012, 08:59 AM
I'm guessing the question is about netiquette rather than mechanics. Quote any part of a post that helps clarify the conversation. Trim unnecessary parts, especially pictures, when quoting unless asking a question about a picture that appeared earlier in a thread. Absolutely avoid quoting entire long posts to follow with an I agree or an emoticon.
post #3 of 5 Old 09-16-2012, 09:05 AM
Assuming you're logged in, just hit the "Quote" button in the message that you want to quote. It will create a new post with the original post "quoted" at the top, so you can add your comments below.
In this case, I hit the Quote button in YOUR message, which makes it appear in the little "quote box" at the top of this reply. Note that while you're actually composing your message, the quoted message will appear wrapped in HTML formatting (it'll have QUOTE=mark2wheeler etc in brackets). This won't appear once you "Submit reply." (or "Preview post") You can also edit the text inside the quote - in this example, I lopped off the second sentence of your post in the quote.
skyguy is offline
post #4 of 5 Old 09-16-2012, 05:28 PM Thread Starter
[ in HTML formatting (it'll have QUOTE=mark2wheeler etc in brackets). This won't appear once you "Submit reply." (or "Preview post") You can also edit the text inside the quote - in this example, I lopped off the second sentence of your post in the quote.[/QUOTE]
Thanks guys.Now I get it.In a post I copied and pasted on something I commented on and of course the reader wouldn't have been able to tell which words were mine and which were from the post I copied.Thanks again
post #5 of 5 Old 09-16-2012, 05:31 PM Thread Starter
Thanks guys.Now I get it.In a post I copied and pasted on something I commented on and of course the reader wouldn't have been able to tell which words were mine and which were from the post I copied.Thanks again[/QUOTE]
test
