led headlight on my Wee - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Rules, Forum Support, Help and Information [NOT FOR MOTORCYCLE RELATED QUESTIONS] Please read the rules before posting. Need help with this forum and it's functions? Post your concern in the relevant category for the volunteer moderators to assist you. [NOT for motorcycle related questions!]
Closed Thread
post #1 of 11 Old 11-03-2011, 09:10 PM Thread Starter
ryoungs2kayak's Avatar
I am toying with the idea of buying a heated jacket and a pair of heated pants (I already have heated grips), but I am concerned that my 2011 Wee could not handle that much demand on the electrical system. I'm thinking I could do all that if I shut off my headlights (daytime only) and used two or more led headlights in their place to remain legal. Has anyone out there tried that? Could I make it bright enough and would it be street legal? If so, I can't find information about it on either this formum nor the internet in general.
[SIZE="5"]Kayaker[/SIZE]
ryoungs2kayak is offline
post #2 of 11 Old 11-03-2011, 09:15 PM
Turning off one headlight will keep you legal and provide enough power.
post #3 of 11 Old 11-03-2011, 09:19 PM Thread Starter
That would probably be a lot easier than putting in led's. Thanks for the earlier reply to my question about how to start a new thread Greywolf. I appreciate it.
post #4 of 11 Old 11-03-2011, 09:44 PM
I don't have one yet, but I'm looking at adding this for similar concerns:
Suzuki VStrom Electrics
WiredDriver is offline
post #5 of 11 Old 11-03-2011, 10:02 PM Thread Starter
Those switches look pretty good. I think that might be the route to go. I have not really decided if I need or want to get heated gear yet. I won't be doing any winter riding, but I will be going over some high mountain passes as well as doing some riding in the far north. If I do decide to get the heated pants and jackets, putting a cut-off switch for one of the two lights would work well. I think I like that a lot better than my idea of getting led bulbs.
post #6 of 11 Old 11-03-2011, 10:12 PM
tmcgee's Avatar
LEDS are not yet bright enough to be legal for headlights and NONE are DOT approved.
tmcgee is offline
post #7 of 11 Old 11-03-2011, 10:14 PM
I'll ride for hours with temps in the 30s with a heated jacket liner, gloves, grips and socks under an Olympia two piece suit. The insulated pants are all I've ever needed for my legs.
post #8 of 11 Old 11-03-2011, 11:07 PM Thread Starter
Will the electrical output on a dl 650 handle an electrical vest and heated grips and a gps? Without unhooking a headlight I mean.
post #9 of 11 Old 11-04-2011, 12:20 AM
Yes. Put in a voltmeter anyway. If you do a lot of time at idle with that stuff on full power, it can be dicey but over 3000rpm should be fine.
post #10 of 11 Old 11-04-2011, 04:04 AM
I run a pair of TT Denali LEDs in addition to my headlights. They consume only 10 watts each and work great as daytime running lights. From a distance they look like they are larger than my headlights and the whiter color makes them much more visible. The are so visible in the day, it appears as if my stock headlights are not even on.
If you disconnect one of your headlights to save the 55 watts of power it consumes, you may consider a set Denali's for extra daytime visibility.
2011 Bullet SXR1100
2009 DL650
Gray Devil is offline
Closed Thread
