Adding or changing a quote? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Rules, Forum Support, Help and Information [NOT FOR MOTORCYCLE RELATED QUESTIONS] Please read the rules before posting. Need help with this forum and it's functions? Post your concern in the relevant category for the volunteer moderators to assist you. [NOT for motorcycle related questions!]
post #1 of 5 Old 02-22-2011, 09:32 PM Thread Starter
pgstrom's Avatar
How do i add or change a quote that will show when i post?
pgstrom is offline
post #2 of 5 Old 02-22-2011, 09:56 PM
K1W1's Avatar
Click on the quote button at the bottom right of the post that you want to quote. You can then edit the quote as you want but remember that it's a quote and you should never change the meaning of what is quoted you should simply delete unnecessary text.
You should also post in the correct section of the forum. I have moved this thread to where it should be.
K1W1 is offline
post #3 of 5 Old 02-22-2011, 10:03 PM Thread Starter
pgstrom's Avatar
Thanks!
Thanks. I see that u moved my question to the appropriate area. I figured it out though so maybe i should delete this thread.
"Normal, good, and average citizens sleep peacefully at night due to the violence that hard men are willing to do on their behalf"- Unknown
2010 DL650 ABS V-Strom Black
pgstrom is offline
post #4 of 5 Old 02-22-2011, 10:03 PM
chicago's Avatar
Select the quote button, bottom right of the post you are quoting. Delete selected parts of the quote if you need, select preview post, review, correct if you need and hit submit.
hopefully I understood your question
14 tooth for me
chicago is offline
post #5 of 5 Old 02-22-2011, 10:04 PM Thread Starter
pgstrom's Avatar
im still learning how to properly use the site.
pgstrom is offline
