Noob - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Rules, Forum Support, Help and Information [NOT FOR MOTORCYCLE RELATED QUESTIONS] Please read the rules before posting. Need help with this forum and it's functions? Post your concern in the relevant category for the volunteer moderators to assist you. [NOT for motorcycle related questions!]
post #1 of 4 Old 08-21-2019, 01:37 PM Thread Starter
Kahukudan's Avatar
Noob
I was directed to this page to fill out my profile, im lost, cant find a button for fill out profile?
Kahukudan is offline
post #2 of 4 Old 08-21-2019, 02:26 PM
Stalky Tracker's Avatar
It is under "User CP". If you are in Classic mode, it is above and on the left. If Full mode, I believe, it is under Tools and then User CP, which would be above center. If Mobile mode, I believe, it is under Menu and then User CP, which would be above and on the right.
If you are still lost, holler.
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
post #3 of 4 Old 08-21-2019, 03:30 PM
EricV's Avatar
At the top of the page in full mode there is a drop down menu with TOOLS. Curser that, click on User CP, then when that page loads, on the left side, top of the column you will see 'Edit Profile'. Click there and the rest should fall into place.
Thanks Stalky, I forgot the classic is different from full mode.
2009 DL-650 ABS 28k
EricV is offline
post #4 of 4 Old 08-21-2019, 03:38 PM Thread Starter
Kahukudan's Avatar
Thanks for the help.
