Private message glitch? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Rules, Forum Support, Help and Information [NOT FOR MOTORCYCLE RELATED QUESTIONS] Please read the rules before posting. Need help with this forum and it's functions? Post your concern in the relevant category for the volunteer moderators to assist you. [NOT for motorcycle related questions!]
 3Likes
  • 1 Post By Brockie
  • 2 Post By ERockJL
post #1 of 7 Old 06-06-2019, 04:08 PM Thread Starter
I've noticed an issue twice now with two different users in private messages. It doesn't happen every time. One private message i responded to a member, one i started myself. I will write the message and send it on its way. Should these be seen in the sent items folder? One time i thought they were. Another time i didnt see it so i sent another message and ended up sending two messages. Is there a delay?
2016 DL1000 ABS
ERockJL is offline
post #2 of 7 Old 06-06-2019, 04:35 PM
Good question. I just received a private message last night, and have tried to reply to it, and the message doesn't show up in the sent folder. I can't tell if my reply was actually sent or not.
V-Strom Ry 2 is offline
post #3 of 7 Old 06-06-2019, 04:55 PM
Brockie's Avatar
Hi Ryan,
For some reason the "save a copy of sent messages" is not turned on by default.
I have just turned it on for you. In future, after sending a PM click on "inbox" and select "sent messages" to see your outbox.
V-Strom Ry 2 likes this.
Brockie is offline
post #4 of 7 Old 06-06-2019, 04:59 PM
Brockie's Avatar
Eric,
I found your setup to be identical. I have turned on your "sent messages" box, and they should now be stored for you.
Brockie is offline
post #5 of 7 Old 06-06-2019, 05:04 PM Thread Starter
so i'm not going crazy, thank you
Brockie and V-Strom Ry 2 like this.
2016 DL1000 ABS
ERockJL is offline
post #6 of 7 Old 06-11-2019, 03:42 PM
SKM348's Avatar
Originally Posted by Brockie View Post
Hi Ryan,
Hey Brockie - I'm having the same issue. I can't find where to 'turn on' the view-sent function. Can you do it please?
Thanks
2019 DL650-XT
SKM348 is offline
post #7 of 7 Old 06-11-2019, 08:29 PM
Brockie's Avatar
Thanks
Done. No worries.
Brockie is offline
