Can't paste links and image links into posts - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Rules, Forum Support, Help and Information [NOT FOR MOTORCYCLE RELATED QUESTIONS] Please read the rules before posting. Need help with this forum and it's functions? Post your concern in the relevant category for the volunteer moderators to assist you. [NOT for motorcycle related questions!]
post #1 of 13 Old 12-12-2016, 12:10 PM Thread Starter
blaustrom's Avatar
I am using IE 11 on two different PC's and since a few days it is impossible to paste regular links or image links. Hope the attached screen shot shows the problem. Is it just me or is there a change in settings that are causing it. I am using the traditional site layout, not the "new and improved" one, which I don't like.
blaustrom is offline
post #2 of 13 Old 12-12-2016, 12:23 PM
Stalky Tracker's Avatar
Worked for me.
Using Windows 7 and IE 11.0.37.
Plus, Classic forum view.
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
post #3 of 13 Old 12-12-2016, 01:26 PM
I can't check your profile until the database is fixed.
post #4 of 13 Old 12-12-2016, 09:26 PM Thread Starter
blaustrom's Avatar
Thanks. The link past windows open but there is already a string in there and blow it basically shows the website The link that is there can't be deleted, so no way to past the link or image link into the field.
EDIT: Just tried it again and it's back to normal so I could post my picture game entry. Thanks :-)
post #5 of 13 Old 12-12-2016, 11:37 PM
Good. The problem could have been a previous link still being there if I get the description of the problem. You can delete the text and type something new and it will show the old link or picture. It works best to put the new link in first and delete the old one later. It appears the software is written so the actual link doesn't get deleted when the text pointing to the linked page gets deleted. You have to make sure you aren't writing on the old link.
post #6 of 13 Old 12-13-2016, 11:29 AM
Administrator
Administrator's Avatar
Glad to hear it sorted itself out.
If an old link was sitting in the URL window, you may need to clear your cache and cookies. Something might have corrupted and keeps overriding your new link with the old and not completing the task properly.
Let us know if it pops up again.
Dayle
Administrator is offline
post #7 of 13 Old 12-13-2016, 02:50 PM Thread Starter
blaustrom's Avatar
Dayle
Must have been something like that. There was no way to type or paste anything in there. BUT it happend on 2 different PC's, both running IE 11. So unlikely they both had the same cache and cookies issue I think.
post #8 of 13 Old 12-13-2016, 02:52 PM Thread Starter
blaustrom's Avatar
It was not a previous link. The link was the home page of stromtrooper, if you look at the screenshot you will recognize it.
post #9 of 13 Old 12-14-2016, 10:35 AM
Administrator
Hey there,
This sounds like an IE11 issue.
When you tried this out afterwards, did you accomplish this within IE11?
Richard.
post #10 of 13 Old 12-14-2016, 03:42 PM Thread Starter
blaustrom's Avatar
Hey there,
Richard.
Yes same machine and software setup, no changes other than what MS pushes out all the time.
