DL1000 clutch levers for small hands - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Rules, Forum Support, Help and Information [NOT FOR MOTORCYCLE RELATED QUESTIONS] Please read the rules before posting. Need help with this forum and it's functions? Post your concern in the relevant category for the volunteer moderators to assist you. [NOT for motorcycle related questions!]
post #1 of 3 Old 10-21-2015, 11:46 AM Thread Starter
RRM
As you know the clutch on the 1000 engages at the end of its movement which, in my case, causes it to slip off the end of my fingers. I know the clutch cannot be adjusted. Has anyone found an alternative lever that may help with that problem or some other fix.
Bob
RRM is offline
post #2 of 3 Old 10-22-2015, 01:04 AM
The clutch lever can be adjusted. Perhaps someone knows the link to the posts about shortening the pushrod from the lever to the resevoir/master cyl. You remove the lever and the little pushrod and then grind off one end of the pushrod about 1/16 inch. It will cause the clutch to engage closer to the handlebars.
bobbyvstrom is offline
post #3 of 3 Old 10-22-2015, 01:05 AM
Greywolf, this thread needs to be moved to a more appropriate category.
