Pictures: Click to view full size - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Rules, Forum Support, Help and Information [NOT FOR MOTORCYCLE RELATED QUESTIONS] Please read the rules before posting. Need help with this forum and it's functions? Post your concern in the relevant category for the volunteer moderators to assist you. [NOT for motorcycle related questions!]
post #1 of 7 Old 04-23-2014, 01:47 PM Thread Starter
I notice at my office pictures always display full size.
At home, they show small with the tag to click to display full size.
Where is that setting for the forum so I can change it to always show the smaller picture?
(Sometimes it is annoying when HUGE pictures come up. I'd rather click to see full size.)
adidasguy is offline
post #2 of 7 Old 04-23-2014, 02:09 PM
Are you sure you aren't just leaving the threads with the big pictures before they finish loading? They don't reduce size until they are fully loaded.
post #3 of 7 Old 04-23-2014, 03:02 PM Thread Starter
Odd behavior on one system.
Windows 8. Firefox.
Other systems it reduces the size.
I removed cookies for ST. Found a setting in the User CP for resizing (which I never messed with on any system).
Does it rely on certain add-ons or extensions being present?
ID works on this system but not Firefox. Firefox is fine everywhere else (I hate IE) so wondering if there is an extension or add-on that is needed?
post #4 of 7 Old 04-23-2014, 04:49 PM
I use Firefox and Windows 7 on two machines. I've never seen a picture stick large. I just found picture resize options in the Edit Options section of the UserCP. Have you tried specific changes rather than default settings?
post #5 of 7 Old 04-23-2014, 06:34 PM Thread Starter
I've looked at the picture resize options. No change.
I suspect there is some add-on that one machine does not have in Firefox. Not sure if it is .net or java or something else causing the odd behavior.
It will take more investigating.
post #6 of 7 Old 04-24-2014, 12:31 PM
Administrator
Administrator's Avatar
The way the images are re-sized is through Java, it is the lightbox feature.
That may be the issue. Try a different browser on the same comp, see if ti changes.
HB
Administrator is offline
post #7 of 7 Old 04-24-2014, 12:58 PM Thread Starter
Thanks. Now I know what to check.
Mozilla is having some issues with updating Java so I'll just work on fixing it on one machine and not let Java do any updates on the other systems since they are OK.
I appreciate the information.
