Is Fresh Pavement Slippery - Page 3 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Riding Proficiency Tips and suggestions for improving the rider's safety skills and riding techniques
 5Likes
post #21 of 22 Old 01-12-2019, 04:22 PM
STCorndog's Avatar
A few notes about asphalt.
We test the stuff routinely for the state and airports. Asphalt is the black part, the glue or tar if you will. Asphaltic concrete is really what the pavement is more correctly called. The asphalt part is only about 4.0 to 5.5 percent of the total volume, with about 90 percent being sand and gravel (aggregate). The 5 percent you might have noticed missing is air filled voids.
As far as what gives better traction, it depends. Generally, new pavement has better dry traction due to the smooth layer of exposed asphalt at the surface. As the pavement wears, the asphalt get scrubbed off the aggregates and the surface turns a lighter shade of grey (or brown depending on aggregate type). The worn pavement takes on a surface more like coarse sand paper and wet traction improves, since the rock pieces stick up through the water.
STCorndog is offline
post #22 of 22 Old 02-09-2019, 03:10 PM
A lot depends on where the road is located. Last year, they repaved a lot of the road at Mt. Rainier National Park, here in Washington State. The section from Longmire up to Paradise was brand new. It is very twisty, and in many spots the drop off is several hundred feet or more. I got about three miles up and said "F___ this!"
It was raining (big surprise) and I was noticing some kind of brownish foam at the edges of the asphalt, and in the ditches. The road was so new, it was the first time it had been rained on, and the water was washing oil out of it. Slicker than deer guts on a doorknob. I stopped in a parking area and did a slow-speed brake test, and there was almost no pressure before the ABS kicked in. My boots had no traction. My rear tire was sliding out on some of the turns at about 10 MPH.
I was about to go back onto the road to head down and a guy heading down on a bicycle came into the parking area, and we talked. He was scared to death, his skinny tires had NO grip and he said it was like riding on ice. I'm a long-time bicyclist so I know that feeling. We went back down sort of together, at about 5 MPH. Made it OK, but it was the scariest I've encountered.
Pirate650
2007 ABS Wee-Strom "The Silver Surfer"
2003 Kawasaki Concours "Mabel, the Flying Kaw"
Pirate650 is offline
Ontario Roads Juan Tanamera Canadian Troopers 19 09-29-2017 12:30 AM
My my Pilot 3s versus Heidenau off pavement Macdoc General V-Strom Discussion 21 08-10-2015 05:46 PM
Seat concepts slippery issue. Eirikur DL650A - 2012-2016 4 06-13-2015 11:41 AM
Dupont Chain Lube: Is it supposed to be thin and non slippery? snakyjake General V-Strom Discussion 25 06-26-2010 06:25 PM
Off Pavement coRoadie General V-Strom Discussion 19 03-09-2010 10:35 PM
