Upshifting speeds - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Riding Proficiency Tips and suggestions for improving the rider's safety skills and riding techniques
 3Likes
post #1 of 11 Old 08-12-2016, 12:08 PM Thread Starter
Upshifting speeds
Am I reading my owner's manual correctly? I should shift from 5th to 6th gear around 37 mph? Really? Page 5-4 of my 2012 DL1K's owner's manual says that is where I should shift from 5th to 6th.
My bike likes to shift at about 4.5k rpms. At 35 mph in 5th gear, the rpms would be way below that.
remoandiris is offline
post #2 of 11 Old 08-12-2016, 12:44 PM
Hard miles's Avatar
I have a 2009 Vee. I up shift at 4000rpm and down shift at 3000 rpm excluding 6th gear. For 6th gear I down shift into 5th at 4000 rpm, otherwise I feel the motor is laboring. You will burn a bit more gas but the bike is more responsive.
Brian
Hard miles is offline
post #3 of 11 Old 08-12-2016, 03:08 PM
fortp's Avatar
Sometimes at 3000 RPM, maybe (I never look at that), and sometimes at 7000 or 8000 RPM. Depend on the situation.
I don't look at speedometer either to decide shifting. It's just feeling... like most do, people I guess.
Hard miles likes this.
fortp is offline
post #4 of 11 Old 08-12-2016, 03:27 PM
The manuals lists minimums, and it would take a perfectly tuned engine at that. Anywhere between those listed and red line would be available shift points with the lower points for economy and the higher points for power.
post #5 of 11 Old 08-12-2016, 05:35 PM
My indicator is sound
klw0472 is offline
post #6 of 11 Old 08-12-2016, 05:46 PM
Wind it up. It's easier for smooth shifting at higher RPMs to get the engine in its upper range. Easier to not close the throttle but just ease back on it, as you snick into the next gear, toe and clutch hand in one motion.
The 1-2 shift I usually make at around 3000 RPM, but beyond that I wind it. I use my ear, not the speedometer, but if I'm trying to get ahead of traffic, I'll get up to highway speeds in 2 or 3.
For cruising, I use this rule:
Under 10 - 1
10-20 - 2
20-30 - 3
30- 45 - 4
...and so on. You can feel, again, when it's lugging too much. Use your gears! The electronic ignition has a rev limiter...it's not especially good to jam it against the redline but you won't ruin it if you do it once in awhile. You'll hear and feel it before then and can check your tach.
JustPassinThru is offline
post #7 of 11 Old 08-12-2016, 05:56 PM
aka Rick in Alabama
basketcase's Avatar
+1
I discovered breaking the bike in that the 5k rpm limit allowed plenty of room and oomph for my usual commuter route. I was careful to mind the stated limits for the break-in period.
However, after the break-in period my shifting became a more complex mix of power needed in relationship to road grade, traffic flow, and safety.
And not to forget, the posted speed limit.
Current rides: 2001 GL1800, 2014 DL650 Adventure; Gone away: 5 BMW's, 4 Honda's, 2 Suzuki's
"The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane." -Marcus Aurelius
basketcase is offline
post #8 of 11 Old 08-12-2016, 07:35 PM
Upshifting speeds
This bike gives you an incredibly wide range to indulge your mood. It's fine (not lugging) as long as it accelerates nicely in the next gear. In between the extremes you can just divide your speed by 10 and run in that gear --- e.g. 4th at 45 mph.
basketcase likes this.
dkayak1 is offline
post #9 of 11 Old 08-12-2016, 11:43 PM
bwringer's Avatar
Yep. I don't know where those ridiculous fictional shift speed recommendations in the manuals come from or what obscure legal requirement they fulfill, but they can, should, and must be ignored.
Yep -- grip it and rip it.
bwringer is offline
post #10 of 11 Old 07-02-2018, 08:55 PM
Quixand's Avatar
Location: "O-H...I-O!" Anybody else like to find those gravel roads runnin' up and down the hills of Ohio?
That's the formula I use, just divide your speed by 10 and run in that gear...
Quixand is offline
