Up-shifting without a clutch - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Riding Proficiency Tips and suggestions for improving the rider's safety skills and riding techniques
 5Likes
post #1 of 11 Old 05-31-2016, 11:20 PM Thread Starter
Vaseface's Avatar
I recently went to a riding course taught by a former racer. He encouraged us to not use our clutch when up-shifting. He taught us to blip off the throttle briefly and then shift up.
He did say to continue to use the clutch when down shifting.
It seems to work fine but takes a bit of getting used to.
Anyone see a downside to this?
Vaseface
Northern California
14 DL1000
Vaseface is offline
post #2 of 11 Old 05-31-2016, 11:30 PM
V-Tom's Avatar
I don't see a downside if done properly and if nothing else being able to shift without the clutch might get you home if you break a clutch lever or clutch cable[it did for me!]
When I first read your post I thought you were saying to "blip" the throttle when upshifting... I missed the word "down" after blip.
To be clear you back of the throttle as you upshift.
Downshifting can also be done without the clutch. It requires a bit more coordination and does require a little "blip" of the throttle so that the revs match.
If you are shifting smoothly with the clutch and are not slipping the clutch then essentially the clutch isn't doing anything anyway.
..Tom
SMIDSY detailed report.
V-Tom is offline
post #3 of 11 Old 05-31-2016, 11:35 PM
Coastie3202's Avatar
A common practice with dirt bikes. Never hurt a thing.
Lacks Self Control
Coastie3202 is offline
post #4 of 11 Old 06-01-2016, 03:56 AM
Sgt Schultz's Avatar
Good practice, and as stated means that if your clutch lever/ cable breaks you are not stuck or too traumatised.
I know nuffink, I see nuffink, It was not me, I was not here.
IBA #45920
FarRider #299
2015 Wee Strom "Piglet"
Givi crash bars, Barkbusters, Ravetech Bash plate, Ravetech Rad guard, Ravetech over dash Ram mount, Hyperlite flashing brake lights, Madstad bracket and screen, Augustus wind deflectors, Spot 3, UHF two way radio, Garmin Zumo GPS, Starcom intercom, Fuze block.
SW Motech Centre stand, Suzuki power outlet. Bike Alarm, Screaming Banshee horn, Led Flood lights, Tool tube, Andy Strapz Expedition soft panniers and frames.
Sgt Schultz is offline
post #5 of 11 Old 06-01-2016, 08:00 AM
I cannot say I recommend it for daily use. Pulling in the clutch lever allows a no load hookup of the gears. If you don't get it just right there is the chance of chipping or mushrooming the edge of the shift dogs. New BMW's have "shift assist" where you simply stab the shifter, either up or down, and it shifts without the clutch lever being used. They obviously have that all figured out. But can you repeat the perfect sequence each time? Yes, It is not all that unusual for me to upshift without the clutch. Like when I am picking my nose with the left hand or just being lazy. Or when hammering the bike. But not every time........
CanadianFZ6 and Brojon like this.
realshelby is online now
post #6 of 11 Old 06-02-2016, 10:40 AM
Spec's Avatar
The downside for me is that I have to think about not using the clutch!
Zook Keeper likes this.
Spec is offline
post #7 of 11 Old 06-02-2016, 12:04 PM
nvr2old's Avatar
On dirt there is give in the rear tire that serves as cushion. I always shifted without a clutch on my dirt bike. When standing it can be harder to access the clutch lever.
On the street, the chance of causing excess wear isn't worth it. Most people aren't that good at meshing gears.
DL-1000 L8
DL-650 K5 red(122K)
09 DRZ400
for the safety of existence.
nvr2old is offline
post #8 of 11 Old 06-02-2016, 04:45 PM
Spec's Avatar
All the gears in the transmission are meshed all the time except in neutral. Neutral just un-meshes (?) the output shaft gear. Gears are selected with a shift fork and dogs that slot into the gears. The dogs need a momentary release of pressure to move in and out of the slots. Clutch of blip of the throttle will do it.
Downs likes this.
Spec is offline
post #9 of 11 Old 06-02-2016, 05:20 PM
Downs's Avatar
Works fine. All the "new" shift assist features do is interrupt the ignition of the bike for a split second to make for smooth clutchless shift. I rode an MV Brutale with the feature and all it was is a microswitch inline with the shift rod.
You can buy kits that do this same thing using a button on the bars. Real popular with drag bike. Hit the switch and the unit interrupts the ignition and a servo shifts for you. Kind of a low tech version of something like Yammie's FJR-AE
2004 DL650 "HMMVStrom"
1978 Suzuki GS1000 "Tennessee Hillbilly"
1982 Suzuki GS850G "Barnfind"
2008 MazdaSpeed 3
https://www.youtube.com/channel/UC8AHz-9CXcxNi5WlDOtYhPA
My channel ^^^
Downs is online now
post #10 of 11 Old 06-02-2016, 06:50 PM
nvr2old's Avatar
Spec- Yes I understand how a constant mesh transmission works..Saying gear instead of "dog" was just meant to mean a gear change without complicating the matter. Improper or forced meshing will cause extra wear no matter what kind of transmission it is.
Kawasakis had some problem with popping out of gear with this kind of abuse.
Spec likes this.
DL-1000 L8
DL-650 K5 red(122K)
09 DRZ400
nvr2old is offline
