Bike Leaning while riding - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Riding Proficiency Tips and suggestions for improving the rider's safety skills and riding techniques
 16Likes
post #1 of 60 Old 08-26-2015, 09:51 AM Thread Starter
Man, this is killing me. The bike leans slightly left while riding, and is exaggerated at speed. I have checked the wheel alignment, suspension alignment, etc. The rear wheel is lined up with the sproket, but I have experimented by moving it left or right, but neither way makes a difference.
I have checked the tire pressure, the handlebar alignment, the grip location, my seating location on the bike, everything I can think of. Bike still rolls down the road and it feels like it is leaning. Only feels straight vertical when the road has a right side crown.
What the heck can it be? And better yet, how can I fix it?
aggiengr is offline
post #2 of 60 Old 08-26-2015, 11:16 AM
Spec's Avatar
Weird.
Maybe the bars are bent, ever drop the bike?
Are you sure it's not the roads you're riding on? Go to a flat parking lot and check it out. How about sticking a level on the bike to verify it is leaning like you think.
Spec is offline
post #3 of 60 Old 08-26-2015, 11:24 AM
Dino M's Avatar
When you take your hands off the bars, does the bike track straight?
Dino M is offline
post #4 of 60 Old 08-26-2015, 11:28 AM Thread Starter
Originally Posted by Spec View Post
Weird.
New bars and risers - everything straight. Old bars were bent, though. Was going to stick a level on the crossbars to see what I see or if it is an optical illusion.
No - it goes left since it is leaning that way.
I have tried moving my hands further left on the bars which would put my weight further left, and push the bike further right to compensate. No cigar.
aggiengr is offline
post #5 of 60 Old 08-26-2015, 11:32 AM
Doesn't everything in Austin lean kind of Left? Maybe go to Waco and try it. :-)
(Just kidding!)
Vaseface and ACKMANDO like this.
2014 Wee
EnduroGuardian bash plate/highway pegs/radiator guard/kick stand switch guard
Givi engine guards
SW-MOTECH Sidestand Foot Enlarger
JeepDawg is offline
post #6 of 60 Old 08-26-2015, 11:35 AM Thread Starter
(Just kidding!)
Funny. But, I truely live in Cedar Park - Williamson county, and there is decidedly a RIGHT lean to this county!
ACKMANDO likes this.
aggiengr is offline
post #7 of 60 Old 08-26-2015, 11:36 AM
Dino M's Avatar
Two possibilities I can come up with:
The alignment can be off and cause the bike to lean since the bike is basically crabbing down the road.
If the old bars were bent, the cause of the bend could have tweaked the triple clamp alignment.
Ozkar likes this.
Dino M is offline
post #8 of 60 Old 08-26-2015, 11:45 AM Thread Starter
I might go ahead and unbolt all the bolts for the triple clamp and "reset" them while it is on the centerstand. I have seen several different methods to check alignment, but non really address how to make sure the tires are vertical!~
aggiengr is offline
post #9 of 60 Old 08-26-2015, 11:45 AM
So the leaning is the symptom. The problem is that the bike wants to turn and you need to lean it to keep it straight.
Something is bent or misaligned. Triple tree or something else. The crash that bent the bars bent more than that. Keep checking.
Bugzy and Ozkar like this.
post #10 of 60 Old 08-26-2015, 12:01 PM
Piece of glass on the fork columns should sit flat.
Distance to rim from each fork column should be the same.
Vertical alignment, bike up against straight wall, measure from top and bottom of each rim to wall.
I haven't done this on motorcycle, just bicycle, but lay out paper on road and ride straight over it, see whether tires are tracking in the same place. Several back and forth can tell a bit.
Odd problem
Bugzy likes this.
50 miles from DGMR
2004 DL1000
2009 Versys 650
2014 Moto Guzzi California 1400
toaster404 is offline
