Scraping pegs on Wee - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Riding Proficiency Tips and suggestions for improving the rider's safety skills and riding techniques
post #1 of 33 Old 07-25-2013, 01:15 AM Thread Starter
I'm amazed that I turned up zero results when I entered "scraping pegs" in the search function! I have had my Wee for about two months. I have yet to scrape a peg and am amazed at how low it gets without scraping. Tonight I got on the freeway on a very familiar ramp that has a nice, slightly off camber 180 degree turn. I got lower today than ever, but still without scraping. My question is, what happens when you scrape? Is there anything solid that hits also or is it just the peg feeler? Also, if it's just the peg feeler, what hits next, and how soon after the feeler hits? Lastly, on a good, smooth asphalt surface, is there much of a margin of traction after the peg scrapes? BTW, I have a Battlewing rear tire that's almost ready to be changed and Trailwing front with about 1/2 the tread left (both soon to be changed to Anakee 3s). Thanks for any advice you guys can give. I'm just trying to get a feel for the limits of this thing without crashing.
divebobber is offline
post #2 of 33 Old 07-25-2013, 01:27 AM
You used the crippled search function. "Pegs" is too short for the index. Use the Google Custom search box instead ro do a Google search on
scraping pegs site:stromtrooper.com
post #3 of 33 Old 07-25-2013, 05:46 AM Thread Starter
Thanks. That worked well.
post #4 of 33 Old 07-25-2013, 10:05 AM
I've scraped the foot pegs on both the left and right side. The pegs do fold but it's still a bit unnerving. I didn't think I was going all that fast for the conditions but the bike was heeled over. Oh, the tires are worn pretty much to the edge in the rear anyway. The fronts never seem to get wear all the way to the edge.
notacop is online now
post #5 of 33 Old 07-25-2013, 10:20 AM
Kind of the same story here. I scraped the pegs on the left, once. I didn't realize that I was swooping that low either. All I remember is my left footpeg was gone (folded up), my boot was dragging the ground and my centerstand was scraping the pavement. Kind of neat in retrospect but unnerving since I wasn't expecting it...:beatnik:
[SIGPIC][/SIGPIC]"Free Men Will Never Consent To Give Up The Means Of Defending Their Liberties"
Buzzzer is offline
post #6 of 33 Old 07-25-2013, 10:26 AM
Usually your boot scrapes soon before or soon after the peg feelers scrape and the pegs begin to fold up. The remaining traction greatly depends on the road surface condition. If the pavement is clean and dry you still have traction to complete your turn. (If we believe we have traction we will have more traction--because it is usually there and most of us don't use it. If we don't believe in our traction we'll do something insane like chop the throttle and be in real trouble.)
If you are a pavement-only rider, consider Michelin Pilot Road 3 or Bridgestone BattleAx BT-023. The PR3 might have better wet traction. Both offer good tread life.
How about a set of sliders. Put the swing arm slider in place of the passenger pegs for more protection.
post #7 of 33 Old 07-25-2013, 12:06 PM
cameraman's Avatar
It depends on how hard you hit and your reaction to it. But hopefully, nothing. The feelers are there to give you warning to knock it off and don't go any further. Going further means low-siding
This also depends, I use to have a sidestand foot bolted on which I had to remove it because it was scrapping long before the peg feeler would hit. Also center stands, Luggage or other low and wide farkles can potentially hit. It also depends on the surface itself... is there a dip in the apex? does the elevation change mid turn? these things can cause you to scrape when if the pavement were flat and in good condition they would not.
Again on the it depends... depends on tire type/brand/size. My current street tire rear is a 140 Tourance, the tire before that was a 170. The 170 had way more room to lean in on it than the 140. but like Goldie Locks, the 170 was too big for my taste, the 140 is too small and the 150 is jussssssssst right. But my next set of street tires will be a purely sport touring tire, no dual sport.
Now my off-pavement tires are knobbies and I don't even want to try to scrape pegs with those tires. They are sketchy enough the way it is on pavement.
Tom G
Atlana
07' weeeeee!!!
cameraman is offline
post #8 of 33 Old 07-25-2013, 12:49 PM Thread Starter
Thanks for the answers guys.
post #9 of 33 Old 07-25-2013, 04:42 PM
OfirMX's Avatar
Scrapping hard parts is not only about speed but has a lot to do with body position too. If you have the right body position you will lean your body into the turn and even hang a bit at higher speeds, that will prevent your bike from leaning too far down.
Or you can turn in slow with a poor body position and scrape your pegs very easily.
Maintaining a proper body position not only allows you to keep the bike more upright during the turn, it also helps you keep your concentration and take the corners more safely.
Proper motorcycle training is like wearing a helmet. You can ride for 30 years without one and make a case that you've never needed it. Until you do but then it's too late to make that decision.
OfirMX is offline
post #10 of 33 Old 07-26-2013, 10:43 AM
Guys like Danny Pedroza drag their freaking elbows. I ain't leaving the seat to do that!
As far as dragging one's boot, I usually put the ball of the foot on the pegs to get my foots out of the way. I've watched the guy ahead have his feet spayed out from the pegs. Just seems wrong to me. I've been guilty of grinding rubber off my boots though!
