When counter steering is not enough - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Riding Proficiency Tips and suggestions for improving the rider's safety skills and riding techniques
post #1 of 31 Old 06-09-2013, 06:38 PM Thread Starter
We've all done it, gone into a curve to fast and ended up on the other side of the yellow line. Good thing there was no oncoming traffic. Here's a trick I learned riding my rode cycle (yes, the spandex kind).
You can TWIST(pull up in one side while pushing down in the other) the handle bars in the direction you want to go and it will give you additional turning power.
Don't believe me, practice it first on a straight away and you will see immediately what I'm talking about. This has carried me through many unfamiliar curves and I hope if you ever need it that it will do the same for you.
Cheyne is offline
post #2 of 31 Old 06-09-2013, 06:49 PM
That isn't twisting the handlebars. It is countersteering. While you said pull up in one side while pushing down in the other, what you are actually doing is pulling the top grip back and pushing the bottom grip forward. That is countersteering and tightens the turn. You have to be turning the bars. No other movement is possible unless you bend the bars and that would not accomplish anything.
post #3 of 31 Old 06-09-2013, 07:18 PM Thread Starter
Meant what I said, not pushing forward on one grip while pulling back in the other but literally pushing DOWN toward tank with one grip while PULLING up on the other, it should feel like your trying to twist the handlebars. I'm sure your correct in saying this IS what us technically referred to as counter steering, now I know- thanks
Cheyne is offline
post #4 of 31 Old 06-09-2013, 08:03 PM
You just think that's what you're doing. Sit on the bike and do the action you are claiming on the bars and see which way they actually move. If you actually move your hands in the direction the bars can really move, you'll stop wasting energy and use a lighter grip.
post #5 of 31 Old 06-09-2013, 08:58 PM
Actually bicycles countersteer too. Its just that with some of your upper body weight always resting on the bars you can easily countersteer by shifting that weight. But it's still only the "steering vector" of that weight shift that countersteers a bicycle. As GW says, no need to push down on a motorcycle. Just (counter)steer.
dkayak1 is offline
post #6 of 31 Old 06-09-2013, 09:04 PM Thread Starter
Talking
Then try it while moving.
I know your not actually twisting or bending the bars, it's simply a mental aid to do something that does not feel physically natural- that in a - oh my god - situation could mean the difference between keeping it between the lines or getting hit head on.
Even a old wolf can learn new tricks
Cheyne is offline
post #7 of 31 Old 06-09-2013, 09:57 PM
kiwi_outdoors's Avatar
all you need to know
push left go left
push right go right
do NOT try and hold the bars in any particular direction at speed
at regular speeds =you guide the bike with force (push on bar) , unlike a car where you can HOLD the wheel and all will be well
kiwi_outdoors is offline
post #8 of 31 Old 06-09-2013, 10:00 PM
I'm aware it's a mental device to make a complex movement seem natural. I much prefer push left go left and push right go right. I didn't know until your last post that you knew it was a mental aid. I like my mental aids to describe the movement better as up and down don't properly describe the actual action. I put it in the same category as "weighting pegs", another bad description that causes confusion. The title, "When countersteering is not enough" is also misleading as the action described actually is countersteering.
Practicing braking and countersteering until the proper movements are in "muscle memory" is what prevents "Oh My God" events. If you have to think, chances are it's too late.
I am an old wolf, just turned 68. I did a paper on countersteering during my MSF instructor course in 1978. I hope to learn something new every day though and most days I do.
post #9 of 31 Old 06-09-2013, 11:52 PM
AmericasFirstFreedom's Avatar
I believe there is a YouTube video about Keith Code's(?) "Twist of the Wrist" that visually demonstrates counter-steering that, when done properly (as in moving the handlebar in the direction it can only possibly move), it is done with very little effort - one finger is what was shown, if I recall correctly.
AmericasFirstFreedom is offline
post #10 of 31 Old 06-10-2013, 06:36 AM
kitesurfer's Avatar
Greywolf, do you remember when the4 first "MSF" course was developed? I had no idea it had been around that long. I had my first course in '78 provided by US NAVY. back then, they threw a 2x4 under your front wheel while riding
2012 DL650
U.S. NAVY, RETIRED
kitesurfer is offline
