Proper shifting - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Riding Proficiency Tips and suggestions for improving the rider's safety skills and riding techniques
post #1 of 15 Old 05-09-2013, 01:31 AM Thread Starter
*noolis*'s Avatar
Proper shifting
Sorry for the newb question, but as I was riding today I started to wonder if my shift technique was proper form or not.
With the slightest pressure up on the gear lever to take up slack, I tend to disengage the clutch at almost the same instant as I shift the gear. It all seems smooth and efficient to me, but, I'm wondering if I need to leave a larger gap in the timing of these two synchronized movements to avoid wear and tear on the box?
Thanks for your help.
*noolis* is offline
post #2 of 15 Old 05-09-2013, 06:15 AM
CanadianFZ6's Avatar
Hard to destroy power train components unless you want to... Basically your gear shift is milliseconds after you pull the clutch in... You don't want to shift like a bike rig where it seems like forever between gear shifts... To me it sounds like you're doing it right... No grinding, serious clunking or crunching, then all is good...
2015 DL650AL5 in Blue
CanadianFZ6 is offline
post #3 of 15 Old 05-09-2013, 08:26 AM
janiceclanfield's Avatar
But, but how do you tell if you've shifted if ya' can't hear the gears?
You mean that grinding noise -isn't- supposed to be there?
Wowzers!
And now back to our regularly scheduled bong...
janiceclanfield is offline
post #4 of 15 Old 05-09-2013, 09:05 AM
jokermtb's Avatar
So that's why the top of my foot is always horribly bruised....!
jokermtb is offline
post #5 of 15 Old 05-09-2013, 10:45 AM
trapperdog's Avatar
What you are doing is called pre loading and when combined with higher RPM shifting you will find that very little clutch lever depresson is needed to shift. However as a newer rider you want to be carefull as a bump in the road could cause a premature gear change without the use of the clutch. Nothing detrimental, but it may startle you especially on a down shift.
Per load shifting is really not necessary on the DL's as they are not race bikes, just something just to play around with. Sounds like your timing is fine since everything is smooth
'09 VEE
'07 HD SEUC
'09 ST1300P
'06 ST1300
trapperdog is online now
post #6 of 15 Old 05-09-2013, 11:22 AM
Sounds good to me. I'm assuming you are pulling the clutch lever about half inch or so? Add two fingers pull with shorty levers, can't really get much smoother than that on with the clutch.
Wilhelm is offline
post #7 of 15 Old 05-09-2013, 11:46 AM
fredellarby's Avatar
Wowzers!
Way too much bong, again.
:beatnik:
Fred
I'm not always sarcastic.
Sometimes I'm facetious.
Or ironic.....
If a tree falls in a forest and lands on a politician, even if you can't hear the tree or the screams, I'll bet you'd at least hear the applause.
Paul Tindale
fredellarby is offline
post #8 of 15 Old 05-10-2013, 02:22 AM Thread Starter
*noolis*'s Avatar
Thanks guys, I appreciate the help.
*noolis* is offline
post #9 of 15 Old 05-10-2013, 06:07 AM
Rolex's Avatar
You have a wet clutch, chain drive and a cushion rear hub, it is very hard to get it wrong or know that you have got it wrong.
Ride a old BMW with a heavy flywheel, dry clutch and shaft drive, you will soon know if your technique is good or bad.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #10 of 15 Old 05-10-2013, 10:48 AM
Your tec. is right. with a little more exp. you will be able to shift without
the clutch, do all practing at lower RPM. I would guess 3500rpm or less.
they shift better going up through gears than down. apply slight
pressure up blip throttle down while lifting shifter. I am 75yrs. & 24
bikes later & have never broken transmision, . They are tough, all bikes
were English or Japanese except 1947 Indian Chief. Present bike 06 Vee
56000mi..
flyspray is offline
