First Impression: 2x2 Cycles Motorcycle Bike Rack - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 5Likes
post #1 of 26 Old 06-06-2012, 12:57 PM Thread Starter
Frequent lurker, infrequent poster...
For those interested, I posted a first impression blog on the 2x2 Cycles Motorcycle Bike Rack over on the Dirt Rag site.
Would love to hear feedback from other 2x2 users for the final print review of the product. Let me know your thoughts, good, bad, or otherwise.
Few teaser pics...
Also posted this on ADVrider, but thought you Stromers might be interested too!
jobestein is offline
post #2 of 26 Old 06-06-2012, 01:59 PM
Oh, this is so cool. I have way more bicycles than motorcycles, and I have been pondering a way to transport one of my mountain bikes to the trailhead on my Wee.
_____________________
Regards, MillCreek
Snohomish County, Washington USA
2012 Suzuki DL650A
Three road, two mountain and one folding bicycle
MillCreek is offline
post #3 of 26 Old 06-08-2012, 06:26 PM
Rick505's Avatar
I just saw one this morning on a KLR 650 parked at the same motel I spent the night. Had Nevada plates and the motel was in Springerville AZ close to the AZ/NM line.
Rick
Rick505 is offline
post #4 of 26 Old 06-12-2012, 12:17 PM
visovm's Avatar
Cool interesting
I have been researching motorcycle bike racks for a while.
This 2x2 system seems to be one of the only ones on the market.
I read the DritRag write up about this and it seems like a great product.
The one concern I have is the amount of weight off the back of the bike and the long term stress from the torsional weight of the bicycle trying to pull the motorcycle rack up.
I wonder if there is a way to mount both wheels up next to the front fork to keep some of that weight over the motorcycle?
Any comments or thoughts on this matter would be appreciated. Might have to rig up my own wheel system to achieve this?
I do like the idea of making the Givi plate along with the 2x2 rack. I will be using the Givi plate way more for my top case, but dont want to change things out every time. I will have to look at my Givi plate and see if it will work like yours did.
Thanks for the write up, i will follow along with this thread.
Joeboblglt likes this.
2008 DL650 (flat black)
2006 Honda CRF250X
2013 Yamaha FJR1300
visovm is offline
post #5 of 26 Old 06-12-2012, 12:34 PM
Hanging weight far from the motorcycle's center of gravity is dangerous. The tail wants to wag the dog. Keeping speeds and maneuvering sedate and adding a Scotts steering stabilizer can help, but I wouldn't do it. Worse things have been done successfully though. Do you feel lucky?
iamsmiling likes this.
post #6 of 26 Old 06-12-2012, 01:38 PM
lordneeko's Avatar
I saw this set-up on the back of a little scooter a while back....I laughed quite uncontrollably.
This actually doesn't look too bad though. The motorcycle is a lot bigger, and it much heavier.
Though I agree with Greywolf, I would imagine a good aluminum bike (many can weigh only a few pounds), would do very little to change the COG on the bike. When you have a 400+ lb bike plus a 180 (ahem 200 lb) pounder sitting on top of it...5-10 lbs on the back really isn't going to affect much. Sure, the fact that it is so far back means that the 5-10lb is more like 30-50 lbs at the luggage rack...but that's still much less than some will put on the luggage rack.
I wouldn't recommend a wal-mart bike though Bike would probably fall apart anyways.
2006 Vstrom 650
1999 Triumph Trophy 1200
2012 Vstrom 650 (current)
lordneeko is offline
post #7 of 26 Old 08-27-2015, 02:21 PM
Hi
Im not sure I'm allowed to post links to other forums, but I asked a question there and no one answered ...
I'd like to get a 2x2 rack to put a downhill or dirtjump bike and also keep my Givi E55 top case (run one or the other, not at the same time
How long does that arm stick out of the back?
I think it's telescoping
Looks like someone did that here
REVIEW: 2x2 Cycles Motorcycle Bike Rack | Adventure Rider
I'm looking to do something similar with my 2004 strom
I live in SF, and park it on the street (w/o bicycle of course
- rack a downhill mountain bike 20mm axle (occasionally)
- also use my Givi E55 top case (left on most of the time to store helmets) and be able to attach/remove it easily (no tools)
- Have the long arm that sticks off the back of the 2x2 rack come off when not being used (does half of it telescope/remove already?, space is a premium in city)
- perhaps get the 2x2 Adventure Luggage Rack /Tray to bring a gear bag of stuff (for mountainbiking)
I don't have side cases (or rack for side case yet), want to keep the bike narrow for lanesplitting
Thinking a 2x2 rack
Suggestions, thoughts ?
Thanks in advance
G
unsavory is offline
post #8 of 26 Old 08-27-2015, 04:06 PM
I personnally have one on my Wee.
Goods: Solid steel construction. Pretty well laid out for what you are getting. Stable. adjustable for different bikes. Comes with everything you need (including additional relocatable LED brake lite to wire in (your stock one is kind of hidden). Lockable forkmount (secure)
Bads: Eliminates trunk capabilities, crosswind sail issues (pass semi's with caution), pricey, the front lip should have been bent up with the same bungie/net mounting holes. You get in a lot of people's pictures that they post online - usually with an "I thought I've seen everything" tag.
Some mods I did on mine after the first couple days: reflective tape everywhere (most people see the moto, but the bike sticking 4 feet out the back - not so much), LED that came with it can be installed with the license plate - I moved it down lower in the fender and permanently wired it in (can see it in side view). I welded some nuts on the underside of my racks so I can unscrew the rack with 4 screws and put on trunk rack with same hardware.
As far as "loading" and weight distribution issues:
1) It will DEFINITELY create a "tail wagging" affect if you do not put on the load distributing strap (goes from rear pegs, wrap over bike stem, and back down.). Cinched down - it shifts the entire CG of the bike to the fron forks (if I forget to secure the cranks down at the middle, the rear wheel will raise up and the bike will levitate and rotate around the front axle).
2) MTB weighs close to 30lbs, plus rack - and with CG shifted as above - it would be worse to haul around another human on the rear seat ~ 8" further forward!.
3) Crosswinds suck - no way around that. Pass semi's with conviction.
Let me know if there is anything else you were wondering.
aggiengr is offline
post #9 of 26 Old 08-27-2015, 04:10 PM
Originally Posted by unsavory View Post
Hi
Thinking a 2x2 rack
Thanks in advance
G
Don't know if they have 20mm axle option - only they can confirm.
Yes, the rear tube will telescope/collapse, but not a lot (down to 2/3 original)
You might be able to rig something up for your Givi - but my trunk is too big to go under the downtube (already tried). I have side cases - so everything goes there (you dont, so maybe a pack on the pillion seat). I wish the area under the bike downtube was setup a little better (more lash points - but remember - that is even more weight further back on the moto rack).
aggiengr is offline
post #10 of 26 Old 08-27-2015, 04:12 PM
Few teaser pics...
Holey shit - that specific article is what made me purchase my rack! I was thinking about it/designing one/etc for quite a while. Then I opened the dirtrag with a strom and a yeti and was on the phone the next morning ordering mine~!
aggiengr is offline
