Murphskits.com Centerstand - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 09-23-2011, 07:15 PM Thread Starter
sgtsandbagger's Avatar
Did as andreas suggested and got 4 replacement M10X1.25 bolts at Ace hardware the same length as the 4 M10X1.5 bolts that came from Murph's. The M10X1.5 bolt threads are too coarse for our Stroms. Didn't need to chase any threads. Easy10 minute install with no instructions. Springs went on a little too easy for my taste.
Used anti-seize on all the bolts.
Grease on the bushings.
Little silicone RTV on the rubber bumper.
Stand is stable and locks up pretty good like the stocker. May modify it a little so it'll "cock" a little more but it's not a have to thing. Also might try loosening the main bolts a little and using red loc-tite for a little looser movement. The bolts you can see on the floor in the pic are the M10X1.5 bolts that are too coarse.
Still can't believe these bikes come without a centerstand.
Good buy in my book!
sgtsandbagger is offline
post #2 of 4 Old 11-13-2011, 05:12 PM
Just installed a Murph's center stand also, used the shoestring trick, to install the springs, much easier than any other method. Noticed it has a very slight lean to the right while up on the stand, still stable, but a few degree lean to the right. All Murph's bolts worked ok but had to chase the threads a little.
06 DL650, 70,000+
ZG1000-rip
K75S-good riddance
TSD1 is offline
post #3 of 4 Old 11-14-2011, 09:26 PM
How do you work in that garage?:mrgreen:
Like the Universal Monocoque stand to.
2003 V - ASV C5 Levers, Univ. Solex bars, grip heaters, ktm mirrors, c.stand, SW Mo Engine grds,Two Bros, PC3, Garmin, Givi 460, tank bag, F. Extenda, BackOff, Super Brace, Elka Shock, Race Tech Gold. AWD/Mr.Ed's Moto seat mod. Dumonde Tech Racing Oil, Spider grips, Contour.
2001 KTM LC4 farkled (sold)
awd505 is offline
post #4 of 4 Old 04-23-2014, 12:27 AM
I installed a Murhp's stand, using the hardware they supplied. It doesn't swing very freely but I also torqued it down fairly well so I'm not surprised. I only expect to use it for maintenance and don't do much offroad, so staying where I put it is fine. I mounted the springs one-at-a-time with a big screwdriver as a bar to pull them; went on very easily. Nice product, good price.
jcork is offline
