Chain Lube - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 6Likes
  • 1 Post By Big B
  • 1 Post By drrod
  • 3 Post By Old Time Rider
  • 1 Post By PerazziMx14
post #1 of 8 Old 12-26-2017, 03:46 PM Thread Starter
Rick505's Avatar
Chain Lube
I didn't see a specific thread for chain lube like oil so thought I'd make a general posting. In any case I "try" and keep my chain lubed but seeing as I rarely see rain, I do admit sometimes I'm a bit lazy. Still try every few hundred miles. Been using a Grease Ninja applicator for a few years and really like it. In any case, I've used several brands of chain lube including the Suzuki stuff. That really made the factory chain quieter but I didn't like the black, grease/tar like stuff that flung off and coated the underside of the chain guard. I think using a sample/door prize can of, I think, Bel-ray clean something made me a convert to the clean style lubes. No more sticky grease stuff in a can. When that ran out, I went on a search and found Lucas Oil makes a chain lube that I've been using for a couple years now and am happy with. Clean applications and it seems to stick properly. Well, I ran out and was on the search for something to try. Since I had a discount coupon for O'Reillys auto, I checked and they have the Lucas and also sell B'laster Chain and Cable Lubricant This isn't the PB Blaster stuff most folks think of when the brand is mentioned. I decided to pick up a can along with the Lucas, hey I had a coupon, and just tried it. I decided to try it with just the included straw and liked the fact that it went where intended and didn't spray all over the place, quick spin of rear wheel and a slow steady shot and it appeared to be evenly applied. I'll let it soak in and when I ride next time I'll check it first. So if anyone is in a bind or just wants to try something different consider trying the Blaster stuff. Oh yeah, being cheap, it was on sale for $3.99 for the 11 oz can. So if it turns out to work like I suspect it will then it's a deal. Of course, you folks who envision themselves as a RTW adventure type and ride right down the middle of the Amazon river might need something more waterproof but for me, I'm OK with trying it out.
Rick505 is online now
post #2 of 8 Old 12-26-2017, 04:05 PM
For years now I just use plain motor oil. Two of my bikes had factory chain oilers. A 66 FLH and a 1974 CB750 Honda. They both got good chain life and the oil they used was just from your motor. On our Alaska trip we all four were on Stroms. They would put them on the stand every day before we turned in and put on the best they thought they could find chain lube. I used plain old oil but put a line on the rear of chain at every stop and sometimes on bottom run. After a week when mine was on stand to look at adjustment and links my friend saw me spin it. He said mine spun better than the other three. It did! So he started using regular oil. The other two did not want it as not as clean.We ran out of chain oil and just refilled bottles to use with oil from the only oil change we made on that trip.Now used oil!
We put new chains on the other two and our two went the 10,300 with over 900 gravel on same chains. That chain went 38,000 on my Wee! So why do anything else?It is not as clean but only a poser wants to be seen on a clean on/off bike.
Old Time Rider is offline
post #3 of 8 Old 12-26-2017, 04:23 PM
Using the Google search bar on this forum, you will see that chain maintenance and lubing is probably the most common asked question/debate here.
SECoda likes this.
post #4 of 8 Old 12-26-2017, 04:26 PM
drrod's Avatar
Duponts Chain Saver is used by a lot of people. It is readily available at Lowes.
https://www.webbikeworld.com/dupont-...n-lube-update/
notacop likes this.
drrod is online now
post #5 of 8 Old 12-26-2017, 07:29 PM
High mile riders are who I look to the most for tips.Even more so if they do own up keep. The one thing that stands out in the past chain lube post of past by high mile and long chain life were the lots that bought the oiler that you fill and is on the bike. This makes it like a old factory one in that its all ways being oiled and you can adjust it. Oiling more than cleaning seems to be the main thing in long chain life IMO.
Wallydog, Brockie and emjrrider like this.
post #6 of 8 Old 12-27-2017, 10:56 AM Thread Starter
Rick505's Avatar
I would have thought motor oil or wind buffeting.
Still nice that I found a $4 item that seems to work....then again only time will tell.
post #7 of 8 Old 12-27-2017, 12:10 PM
PerazziMx14's Avatar
Chain oilers work so well because continuously lubricate and actually clean the chain. As the dirt/grime sticks to the lube it becomes to heavy to stick and is flung free of the chain thus continually cleaning the chain as well as continually lubricating it.
Big B likes this.
PerazziMx14 is online now
post #8 of 8 Old 12-27-2017, 12:32 PM
Yup I have tried pretty much all of the popular and even not popular lubes, got a Tutoro chain oiler and will never own a chain drive bike without one again.
