Put her to sleep. - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
New England Maine, VT, NH, RI, CT, Mass
 33Likes
post #1 of 59 Old 11-17-2018, 04:11 PM Thread Starter
Put her to sleep.
Put the bike to sleep two days ago. Yesterday was a wet 6-8" snow. Salt went down on the roads. So, she was put in her corner of the garage. Tire pressures updated. Oil very recently changed. Treated gas up to the brim on the tank. Dryer sheets placed in and around her ( discourages mice ). Put 'er on the battery tender and said g'night!
Till we get a good cleansing rain come springtime, she's hibernating.
Happy Thanksgiving all. :-)
gary
chicago, Lrobby99 and Vpower55 like this.
gary
'14 VStrom 1000
Security is mostly a superstition. It does not exist in nature, nor do the children of men as a whole experience it. Avoiding danger is no safer in the long run than outright exposure. Life is either a daring adventure, or nothing. - quote attributed to Helen Keller.
RebornRider is offline
post #2 of 59 Old 11-17-2018, 04:37 PM
Lrobby99's Avatar
gary
Didn't pull battery? Just clamped on and plugged in the Tender?
I'm debating. Bike is against a warm wall in an otherwise cold garage attached to house.
Also I pulled the mirrors and windshield. For safer keeping.
I don't use dryer sheets. I use liquid fabric softener. Much better. So, that could be a problem.
2018 1000XT, black. The Night's Watch. Givi engine bars, rear wheel mud guard, radiator screen. Givi V56 Litre Monokey topcase. Puig screen. Freeway Blaster horn. Speedohealer. SW Motech guards for R. brake reservoir, R. brake cylinder, exhaust pipe valve. Aprilia Tuono mirrors.
Lrobby99 is online now
post #3 of 59 Old 11-17-2018, 05:30 PM
Stalky Tracker's Avatar
Mine was put up a few weeks ago, some snow on the ground and roads.
Here's my routine: I usually start with an oil and filter change (unless recently done), check tire pressures, add Marine Sta-Bil, top off the gas tank, take a brief ride to run the mixture through the system, swap positions with the snow blower in the garage, put on center stand, slide vinyl/rubber floor mat under front tire (old wives tale but I do it anyway), plug in Battery Tender to bike and wall outlet, set out several boxes of d-CON poison, and throw the mc cover over it. And hope spring comes early.
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
post #4 of 59 Old 11-17-2018, 06:14 PM
I try never to put my bikes to sleep. Here in the Midwest you just never know when you'll have a warm(er) sunny day to ride, and if all the planets align, I wanna be out there enjoying my bike.
Tank full, tires checked every week, tethered to the Battery Tender at all times. It's ready when I am.
MAZ4ME is online now
post #5 of 59 Old 11-17-2018, 08:42 PM
ironmorph's Avatar
Send a message via AIM to ironmorph
Mine has been put up since I broke my femur 2 months ago. I put stabil and place it on a tender, other than that, it will be ridden the next sunny day, even in the middle of Winter. Lots hinges on my recovery though.
Lrobby99 likes this.
ironmorph is offline
post #6 of 59 Old 11-18-2018, 05:04 AM Thread Starter
Lrobby, yep.... didn't pull the battery, just put it on a tender via a pigtail attached to battery. Never had a problem with that with several bikes over several years.
For you guys that ride on those nice sunny 50+ degree days in the winter..... Well, the thing that keeps me off the road is the SALT. Even on a nice day, all that salt dust is still on the roadways. You can see it on every cage on the road. It's almost atomized. And it gets into all the little nooks and crannies on a motorcycle. Maybe I'm over paranoid about this, but just picture an electrical failure the following August, hundreds of miles from home from some connection that just corroded out due to salt. I've got no problem riding in cold weather - heated gear; but it's the salt that keeps me off the roadways until a cleansing rain or two in the spring.
If yer riding..... ride safe all.
gary
Lrobby99 and eagleeye like this.
gary
'14 VStrom 1000
post #7 of 59 Old 11-18-2018, 07:15 AM
6 of one
On some of my other bikes, I leave the batteries in and just charge them periodically (after determining there's no current draw to run them down). But it is so easy to pull the Vee battery that I do it and put it on the bench, where it also gets periodically charged. Kind of moving away from tenders on those that do not drain the battery, as it is just a waste of power. In contrast, my Boxster has a huge current drain while turned off, so it lives on the tender, even during the summer months.
A few years ago they started using 'brine' on the streets prior to an expected ice storm or snowfall. It seems to be much more corrosive than salt, it dries to a very fine powder that arises in clouds when stirred up by traffic. And it is slippery when wet. So once the brine goes down, the bikes stay in.
Used to take my Airhead out in the winter on warm days. The first year they 'brined', found all sorts of rust spots in the nooks and crannies of the frame. Never had that problem with salt. Spent most of that spring cleaning them up. No more winter riding.
And I usually wait for the first big rain of the spring to wash all the residue down the drain. Fortunately that usually happens before it gets all that warm.
Jimding is offline
post #8 of 59 Old 11-18-2018, 07:23 AM
PerazziMx14's Avatar
Next thing to do is go back out to the garage and unplug the battery tender. There is no need to keep it plugged into the bike 24/7 You risk the chance of over charging the battery.
PerazziMx14 is offline
post #9 of 59 Old 11-18-2018, 08:20 AM
Forest Cop's Avatar
Some of us...'r...a few of us Canucks try to ride all winter. OK, maybe just me! I'm in Midland which is about 2 hours North of Toronto on the shores of Georgian Bay, and we tend to get some pretty windy snow squalls off the lake, but if you pick your days and the roads are dry.....I'm out there!
Last year, my final day was December 12th and I had it back out on February 2nd. Coldest day so far was minus 12 Celsius....a wee bit nipply!
Ride safe guys, and Happy Thanksgiving to our 'Merican friends.
Larry
snorkie likes this.
Forest Cop is offline
post #10 of 59 Old 11-18-2018, 10:07 AM
Highwayman2016's Avatar
gary
Ok, for a minute there I thought it was euthanasia.
2014 650 Strom
Highwayman2016 is online now
MRV's 2014 MERA "5 & Dime" Rally Report MRV Ride Reports (Route Sheets) 5 09-13-2014 10:16 PM
