Put her to sleep. - Page 3 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
New England Maine, VT, NH, RI, CT, Mass
 33Likes
post #21 of 59 Old 11-18-2018, 07:37 PM
The Juniors that have failed all have had one tip-off to the electronics failure: The green LED will flicker erratically. According to Deltran, there is no other cause for that other than an internal electronic failure.
With other chargers, or ones that have had too high a rating for the amp/hr capacity of the battery, I have seen batteries melt, boil over, remove paint, and etch frames. But all those cases were with lead-acid batteries, never with an AGM battery. Either I have been extremely lucky these past 20 years or AGM batteries just do not boil over, melt, catch fire, or a Battery Tender Plus malfunction doesnt happen, or a combination of the 2.
When I do take one of my bikes out, the power strip for all 3 Tenders is switched off, so periodically all of the bikes see no charging or tending action.
The Plus charging rate at full tilt is 1.25A, the Jr. is .75A. Enough to possibly, evenutally rin a battery dry, although before my bikes used AGM and I was using lead-acid batteries, I never had a battery run low. Deltran did warn about this in the manual supplied with the Tender.
The original Tender used a translucent plastic 2-wire connector, square on the bottom, roof-shaped on top. The Tender Plus that succeeded the Tender use a SAE rubberized molded connector, with an encapsulated female terminal and an exposed male terminal.
The charging rate strategy was also changed in the Plus to me more compatible with the AGM batteries that succeeded the lead-acid batteries. The Plus works well with both lead-acid and AGM, but the original Tender had problems charging the AGM.
In any event, I check my battery capacities at least once every 2 months. When I see that capacity dropping, the battery gets replaced.
My sister-in-law who lives in Florida 4 months out of the year was hesitant to use a Battery Tender in her '05 Mustang while she was gone, claiming she heard of battery maintainer-caused fires. A call to the local department told her the reasons for the fires were people using damaged extension cords between the wall outlet and the Tender. I keep mine plugged into the wall outlet, but instead of using an extension cord, I use a Battery Tender extension cable between the Tender and the battery. As I said, 20 years and not an issue whatsoever.
The recommended initial charging rate is 1/10th the amp-hr capacity of the battery X 10 hours. Beyond the initial charging procedure, the 1/10th recommendation still applies. According to Yuasa, the YTX12-BS as used in a '04-'17 DL650 Vstrom 10 has a rating of 10 amp-hours. The Tender Jr would be ideal having a maximum charging rate of .75 amps. The '02-'16 DL1000 Vstrom uses a YTX14-BS, which has a rating of 12 amp-hours, for which the Tender Plus would be a better choice as it has a charging rate of 1.25A. All 3 of my bikes have batteries of a 12 amp-our rating and are on Pluses. My son's SV650, with the YTX-12BS sits on a Battery Tender Jr.
I dont worry about any of the 4 in my garage, but I am vigilant.
MAZ4ME is offline
post #22 of 59 Old 11-19-2018, 02:05 PM
vinnyvavoom's Avatar
Originally Posted by RebornRider View Post
Lrobby, yep.... didn't pull the battery, just put it on a tender via a pigtail attached to battery. Never had a problem with that with several bikes over several years.
For you guys that ride on those nice sunny 50+ degree days in the winter..... Well, the thing that keeps me off the road is the SALT. Even on a nice day, all that salt dust is still on the roadways. You can see it on every cage on the road. It's almost atomized. And it gets into all the little nooks and crannies on a motorcycle. Maybe I'm over paranoid about this, but just picture an electrical failure the following August, hundreds of miles from home from some connection that just corroded out due to salt. I've got no problem riding in cold weather - heated gear; but it's the salt that keeps me off the roadways until a cleansing rain or two in the spring.
If yer riding..... ride safe all.
gary
I will ride the strom down to about 45 degrees for a quick jaunt, half an hour or so in one direction, over 50 and I can ride all day. Below 45 and the Wing comes out instead. I can ride it down to 32 degrees all day. I have ridden on rare occasions when truly inspired below 32 but the roads have to be dry. As for salt, I live with it, neither of my bikes will win the "best kept" award.
_______________________________________________________________________________
There are 10 types of people, those who know binary and those who don't.
What I ride now:
2013 Honda GoldWing (The Lady)
2014 V-strom 650 (The Mistress)
Previously: 07 Ultra Classic, 95 Softail, 80 gs450l
vinnyvavoom is offline
post #23 of 59 Old 11-19-2018, 03:17 PM
DonOhio45813's Avatar
Originally Posted by eagleeye View Post
Even the cheap ones from harbor freight, no problems.
Just found the HF tender on my Wee was putting out nothing. You need to verify the voltage output occasionally. All looked normal, but the battery was dead, and tender output was 0.0
DonOhio45813 is offline
post #24 of 59 Old 11-19-2018, 03:52 PM
Lrobby99's Avatar
[QUOTE=RebornRider;5325473
gary[/QUOTE]
Agree completely.
There was a thread here last Winter about a guy trying to sue Suzuki b/c his new DL1000 was rusting and pitting.
He rode a few roads with some level of salt contamination, and that was all it took.
No one here gave his lawsuit a fart's chance in a tornado.
2018 1000XT, black. The Night's Watch. Givi engine bars, rear wheel mud guard, radiator screen. Givi V56 Litre Monokey topcase. Puig screen. Freeway Blaster horn. Speedohealer. SW Motech guards for R. brake reservoir, R. brake cylinder, exhaust pipe valve. Aprilia Tuono mirrors.
Lrobby99 is offline
post #25 of 59 Old 11-19-2018, 04:12 PM
Just got back from checking on the girl.All is good she looks well and to think 1 month down 5 1/2 more to go.
Vpower55 is offline
post #26 of 59 Old 11-19-2018, 04:39 PM
Not time in east Tennessee yet. Saturday we rode the newly opened "missing link" of the Foothills Parkway. Mid fifties , sunny and dry , heated gear on low or switched off. Probably will be close to Christmas before time for it's winter nap . Set the alarm for mid March.
2014 DL1000 - It's like a DL650 ....but for men.
2010 Triumph Scrambler-current
2014 KLR650 - current
2017 Honda CRF250L - current
Past bikes - too many
Carrot Cake is my favorite vegetable.
Slow Eddie is online now
post #27 of 59 Old 11-20-2018, 05:58 AM Thread Starter
Slow Eddie..... do they salt the roads down there?
Ride safe all that ARE riding.
g
gary
'14 VStrom 1000
Security is mostly a superstition. It does not exist in nature, nor do the children of men as a whole experience it. Avoiding danger is no safer in the long run than outright exposure. Life is either a daring adventure, or nothing. - quote attributed to Helen Keller.
RebornRider is offline
post #28 of 59 Old 11-20-2018, 08:29 AM
I've only seen and heard of gravel here in Blount County. I've never seen salt or brine used on any of the parkways, either . I live on a steep road and they use gravel only . In Knoxville they use a lot of salt and brine. Both are nasty . but necessary I suppose.
post #29 of 59 Old 11-24-2018, 09:08 AM
om28's Avatar
Winter has come early and caught me off guard, I haven't winterized my bike yet. I do the typical: treat gas, change oil if over 2K miles, pull battery and keep charged, wash bike if dirty, mist cylinders if I'm feeling energetic.
One thing that's not typical is that I store the seat inside and treat it with a vinyl conditioner. Over years the cold will dry and crack the vinyl, it also prohibits mice from nesting under the seat. I check and/or replace the air filter in the spring, and I'll evict any mice that have moved in over the winter. I found them once under the seat and never in the airbox.
RebornRider and Hatchi like this.
2009 Wee Strom ABS (current)
1987 Harley Low Rider Sport (current with 200K miles)
2009 Aprilia Mana 850, 2006 SV650, 1984 Yamaha Virago 1000 (all sold)
Silver Strom Club Member #11
Wee Farkles in order of importance: Russell Day Long Seat, Madstad with Moose Adventure Shield +4'', SWMotech Centerstand, Givi XS308 Tankbag, Aprilia mirrors, Framesliders, Fenda Extenda, Elka Shock.
om28 is online now
post #30 of 59 Old 11-25-2018, 06:52 AM Thread Starter
Some good ideas here! I like the idea of removing the seat to deny mice that shelter they often seek. Gonna do it! Thanks!
Is it spring yet? :-)
g
Hatchi likes this.
gary
'14 VStrom 1000
MRV's 2014 MERA "5 & Dime" Rally Report MRV Ride Reports (Route Sheets) 5 09-13-2014 10:16 PM
