Need someone to ride my wee, central MA. - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
New England Maine, VT, NH, RI, CT, Mass
post #1 of 11 Old 06-18-2016, 04:29 PM Thread Starter
I just picked up a wee and would like someone that has one to make sure the steering feel is normal. It's been ten years since I rode a similarly styled motorcycle and I am coming off a Honda 919 so it could just be me.
Please let me know if you are in the area.
Thanks
I'll supply lunch
Sent from my SM-G900V using Tapatalk
jakes01234 is offline
post #2 of 11 Old 06-27-2016, 07:06 AM
sbeadg's Avatar
Have you checked the fork bushings?
If you can stabilize the bike with the front wheel off the ground, take a fork in each hand and listen/feel for any movement, you need bushings.
That happened to my bike and it is noticeable. The check is more definitive than "ride" feel too. Good luck with it.
'15 Tiger800 XRx
'99 Triumph Thunderbird Sport
'89 Honda NX250
"Why don't I have tattoos? For the same reason you don't put a bumper sticker on a Ferrari."
sbeadg is offline
post #3 of 11 Old 06-27-2016, 08:39 AM
Arrowhead's Avatar
When I picked up my '08 Wee, I was a afraid I made a mistake in buying it at first as it was sooo sensitive to bar inputs it was not fun to ride. Turned out the rear preload was soft and the front was cranked all the way up. Add that I'm a heavy guy and it really screwed up the steering geometry. I got the sag setup properly and it was like a new bike and handled just fine. So that might be a good place to start whether that is the problem or not.
'14 Vee2
Arrowhead is offline
post #4 of 11 Old 06-27-2016, 09:48 AM
Nostromdumbass's Avatar
True. Chassis geometry is set, maintained and controlled by 3 springs. Damping controls the springs. Proper setting equals rider confidence. Leaving it to chance will most often result in a less than optimal riding experience. Extract more joy from your bike by spending effort on this before any other farkle...IMHO
An original quote by Nostromdumbass;
Facebook: making humanity yearn for the times when people used to talk behind others backs.
Nostromdumbass is offline
post #5 of 11 Old 06-27-2016, 09:52 AM
if you can make your way out to Walpole I can take a look. I can lift the front in my garage.
mcrag is offline
post #6 of 11 Old 06-27-2016, 10:03 AM Thread Starter
I checked everything over in the front end and it feels fine, I loosened up the fork tubes and re torqued all the fasteners and made sure the bearings are good.
I'm thinking what I am feeling is just the shinko 705 front. When doing a quick right to left (or opposite) it feels like the front end is made of rubber hahaha. I'm starting to think the tread blocks are just deflecting causing this feeling.
I'm getting used to it now, have about 500 miles on it, was just a big change.
So whoever wants a 705 shinko with a few hundred miles on it, itll be free hahaha ordering new tires this week when I decide what I want.
post #7 of 11 Old 06-27-2016, 11:32 AM
Kelly2012's Avatar
I didn't care for the 705 front. Most people are either ambivalent about the trade-offs, or dislike them. They are a "unique" handling tire.
Kelly2012 is offline
post #8 of 11 Old 06-27-2016, 11:42 AM Thread Starter
I had tkc80s on my gs and I don't remember it handling this way. Maybe I just got used to it quickly or the shinko and I just are not meshing.
post #9 of 11 Old 06-27-2016, 03:05 PM
Arrowhead's Avatar
Known handling trait of the 705 - BUT it will fade as the tire wears. Spend some time on some twistys and get the corners of the lugs to break in and that will help. Love my 705's for dirt road ridin.
'14 Vee2
post #10 of 11 Old 07-26-2017, 02:09 PM
Did the tires make a difference? I'm on the border of mass (Keene) and we can meetup if you want to compare to a 1000
Hdgunnell is offline
