Sprocket Carrier Bearing Part Number? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 16 Old 09-12-2011, 08:42 AM Thread Starter
I searched, but apparently my google-fu skillz are lacking this morning... Does anyone have a part number for the OEM sprocket carrier bearing? From there I know my local bearing house can cross it to a double-sealed one.
Thanks!
ETA: I should have been more clear: I'm looking for a manufacturer and part number off the actual bearing that's in the assembly, not the OEM number from the OEM parts diagrams. Suzuki doesn't make their own bearings, so I would expect to find an INA, SKF, Timken, FAG, or some other manufacturer's logo and part numbers etched into the OEM bearing...
gijoecam is offline
post #2 of 16 Old 09-12-2011, 10:11 AM
Find a local bearing house
Take the bearing there and let them measure it
get it replaced by a new DOUBLE sealed unit hopefully NOT out of China.
I also like GREEN loctite that goes around the OUTER race to support it in the housing. Bearings that are poorly designed like this do get support from the assembly they are in
richw is offline
post #3 of 16 Old 09-12-2011, 10:14 AM
Suzuki #: 09262-32007
Common #: 62/32-2RS
post #4 of 16 Old 09-12-2011, 10:44 AM
Bearing supply houses typically cannot cross reference to manufacturer's part numbers. They can easily measure an old bearing or seal and pull one off the shelf that matches.
post #5 of 16 Old 09-12-2011, 11:07 AM Thread Starter
I know that. I'm trying to amass the parts ahead of time. Removing the bearing and taking it to the bearing supplier means I can't ride it. Suzuki does not make their own bearings, and I figured somebody that has removed the bearing must have found a manufacturer and part number laser-etched into one of the races that can be interchanged with another bearing manufacturer's parts. The dimensions are a good starting point though...
Common #: 62/32-2RS
Thanks, greywolf. It is a single row ball bearing, correct? Would you happen to know if it's a straight-contact bearing or an angular-contact bearing? I would think it's straight-contact but haven't had mine out yet to see...
gijoecam is offline
post #6 of 16 Old 09-12-2011, 11:40 AM
It's a single row bearing, not angular contact.
post #7 of 16 Old 09-12-2011, 01:24 PM
The different suffixes show the various shields and seals available. Shields have a gap sufficient for oil (and dust) to flow through. Resilient seals keep dirt out and factory grease in, and we want two resilient seals, i. e., -2RS. Some bearing makers use different designations for seals that do the same job, but ask for 2RS and you'll get the right thing.
Note that these are open bearings without seals, not what we want, and that these have a groove for a locking ring, also not what we want, but it shows the bearing well. The 62/32 is 65mm OD, 32mm ID, 17mm wide.
post #8 of 16 Old 09-12-2011, 02:17 PM Thread Starter
Thanks for the info, guys. Found a place locally that can get them for me... But they want $52.72 for ONE... Seems a little pricey to me... I'm thinking that I can buy 5 seals for the same price and keep the stock one in there at this point. Not exactly thrilled with the idea of spending that kind of money on ONE bearing...
edited:
Maybe my Google=fu skillz aren't so bad... Found 'em: http://www.thebigbearingstore.com/se...Bearing/Detail
Looks like about $20 shipped to my door... Still crazy expensive shipping for an $8 bearing though... SOMEbody has got to have a part number, either off the original or off the replacement that I can cross-reference...
gijoecam is offline
post #9 of 16 Old 09-12-2011, 04:51 PM
What more do you want? You have the numbers and size.
post #10 of 16 Old 09-12-2011, 06:37 PM
Its your fault because you live in Michigan where there are no bearings
richw is offline
