Wee won't start, rapid relay clicks. - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 31 Old 07-27-2009, 03:07 AM Thread Starter
Battery voltage reading 12.8 across the terminals.
Turn the key and everything cycles.
Hit the starter button and headlights dim and the motor sounds like it turns maybe half a rotation and the relay rapid-fires until I let off the button.
Hit starter again and I just get the rapid clicks.
Battery is new this spring.
I rode it home in heavy rain the night before but it ran fine.
Any ideas?
oconnor is offline
post #2 of 31 Old 07-27-2009, 05:33 AM
What Kinda Bike Is That?
Black Lab's Avatar
Make sure your kill switch is not set to "off".
Black Lab is offline
post #3 of 31 Old 07-27-2009, 07:32 AM
redhot's Avatar
A flat battery can still measure full across terminals.... and it sounds classic FLAT to me....
redhot is offline
post #4 of 31 Old 07-27-2009, 07:39 AM
tmcgee's Avatar
Sounds like a battery problem to me. What does the meter read when you push the starter switch?
tmcgee is offline
post #5 of 31 Old 07-27-2009, 10:37 AM
Banned
Sounds like the battery to me too. Put the meter on the battery and watch it when you hit the switch. Does it sag down pretty far? A meter is basically no load on a battery. The starter, on the other hand, is a heavy load.
Check to make sure your terminals are clean and tight... another possibility.
Trooper32 is offline
post #6 of 31 Old 07-27-2009, 11:23 AM
dtcjem's Avatar
I had a similar problem and it turned out to be a loose / poor battery connection.
09 DL650 ABS - Shad 37L top box / OEM Center Stand / Garmin 60CSX / Givi Bars / Caribou 37L Top Load / OEM Handguards / Madstat / AirHawk /GenMar up and back / Sirius Radio /Starcom1/More to come
<a href="http://www.fuelly.com/driver/dtcjem/dl650" target="_blank"><img src="http://www.fuelly.com/smallsig-us/43311.png" width="115" height="40" alt="Fuelly" title="Share and compare MPG at Fuelly" border="0" style="border:solid #ccc 1px;padding:4px;background:#fff;"/></a>
dtcjem is offline
post #7 of 31 Old 07-27-2009, 12:41 PM
Bisbonian's Avatar
This is where I was going as well. In addition to the battery ends check the end on the starter and wherever the negative cable grounds.
Go hang a salami I'm a lasagna hog
Bisbonian is offline
post #8 of 31 Old 07-27-2009, 12:48 PM
OydnaR's Avatar
sounds like a flat battery to me as well
fwiw, a fully charged battery for our 12 volt system is 13 volts
IBA#9560
Copyright (c) 2019
OydnaR is offline
post #9 of 31 Old 07-27-2009, 01:07 PM Thread Starter
Terminals are tight.
Pulled it off the charger.
Got the bike started.
At idle the battery reads 13.00-13.1 or so.
If I just touch the throttle the reading jumps to 14.6 and stays there to 5,000rpm.
15 min later battery reads 12.8
I turn the key on and hit the starter and it won't start, battery showing 9.10 or so while cranking.
This is the second battery from this vendor, first wouldn't hold a charge over 12.5.
oconnor is offline
post #10 of 31 Old 07-27-2009, 01:43 PM
Banned
Seems to me that something isn't right in the charging system. Did you get out there and ride and get a good charge on that battery?
