Fork oil change recommendation - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 16Likes
post #1 of 20 Old 10-24-2019, 12:38 PM Thread Starter
Vlad1slav's Avatar
Question Fork oil change recommendation
Hi everyone,
I have a novice question today, I was wondering when it's advisable to change the fork oil? I just bought a 09 650 V-strom (8k mileage) and was wondering whether the fork oil change is more related with the age of the motorcycle or the mileage (or both)?
Thanks in advance for your replies!
Vlad1slav is offline
post #2 of 20 Old 10-24-2019, 12:43 PM
There are those that will recommend a few year interval. I don't get around to it often on my bikes. i know it can get right funky after a number of years.
It's a bit of a bother but it will help the bike ride better.
On my 04 wee I've done one side when I replaced a blown seal. Changing viscosity can help with how the fork feels too depending on your weight and riding style.
richlandrick and Vlad1slav like this.
post #3 of 20 Old 10-24-2019, 02:12 PM
Rolex's Avatar
Notacop is right your old oil will stink and a change will help.
Now the problem is oils aren't oils, a 10w in one brand will be different to a 10w in another brand so you have some reading ahead of you.
I used (ATF) automatic transmission fluid in my 09 Wee and I was happy with the results.
All my farm bikes also get ATF, it lasts longer than fork oil and seems to stay behind the seals better, EG: less leaks past old seals.
Vlad1slav likes this.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #4 of 20 Old 10-24-2019, 02:15 PM
PerazziMx14's Avatar
If you have the skill set or a friend to with the skill set assist go for it.
It also a excellemnt time to upgrade the fork internals if you want too and have the guap to do so. Springs rated for your weigh and riding style coupled with some fork inserts (Ricor and/or Gold Valve) and matching fork oil and fork brace will greatly improve and somewhat modernize the front suspension. Be forewarned once done this will then expose how the rear shock and spring need reworked to match the front.
PerazziMx14 is offline
post #5 of 20 Old 10-24-2019, 02:41 PM
BC Rider's Avatar
The forks are fairly well sealed. I find most contamination is metal from the springs rubbing on the tube walls. If water works its way past the seals that metal turns to rust and the oil goes funky. Small amounts of dirt and bug guts will work their way through and add to the soup. It is a bit of a project to do so I like to do it in the winter when I can. 8 thou is not that much mileage but 10 years is a lot of time. I would change it, if there is a bit of water in there other parts can rust. After changing, the oil will be at the correct level and weight, and your ride should improve.
13 DL650 Current ride
80 CX500D
77 XS360
78 XS750
76 CB360T
BC Rider is offline
post #6 of 20 Old 10-24-2019, 04:17 PM
Big Boy's Avatar
Here's a fork oil comparison chart.
BC Rider, Jhat and Vlad1slav like this.
W. C. Fields
Big Boy is online now
post #7 of 20 Old 11-20-2019, 08:25 AM Thread Starter
Vlad1slav's Avatar
Thank you everyone for your inputs!
post #8 of 20 Old 11-21-2019, 02:59 AM
Gert's Avatar
Have you read https://blacklabadventures.com/2012/...nt-fork-seals/? Useful info even if you are not replacing the seals.
Gert is offline
post #9 of 20 Old 11-21-2019, 10:01 AM
Big Boy's Avatar
My Experience
When I changed/upgraded the fork springs on my ZRX, I went with 1.1 Kg springs and 15 weight oil. Massive improvement. Note: I weigh 265 lbs which is at least 275 lbs when I geared up.
W. C. Fields
post #10 of 20 Old 11-21-2019, 04:45 PM
RichDesmond's Avatar
I generally do it in conjunction with a front tire change. With the wheel off I'm already half way to have to having the forks in my hand, so it's the logical time to do it.
Rich Desmond
RichDesmond is offline
