Chain link replacement - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 16Likes
  • 5 Post By dravnx
  • 2 Post By Max in Montreal
  • 5 Post By bwringer
  • 3 Post By BTF/PTM
  • 1 Post By Motorpsychology
post #1 of 9 Old 10-22-2019, 05:46 PM Thread Starter
Max in Montreal's Avatar
Link in chain making clicking noises when going around the big sprocket. I have applied extra lube and the sound is gone... but should I worry? if needed, can I replace just the link, or must it be the complete chain?
Max in Montreal
2005 DL1000
Max in Montreal is offline
post #2 of 9 Old 10-22-2019, 06:20 PM
dravnx's Avatar
Kinked link=replace chain and sprockets.
L2 DL650 Adventure
bike X miles=smiles
smiles bike=miles
smiles miles=bike.
It's simple math.
https://www.directavionics.com/
dravnx is online now
post #3 of 9 Old 10-22-2019, 07:21 PM
BC Rider's Avatar
If you have the tools it is possible to change one link on a chain. Grind, press out pins, install new masterlink in place of it. The fresh grease and O rings might help. But really, if the chain is starting to kink it is time to start looking at a new chain and sprockets. You can make it last a while more but keep an eye on it. Could have been a spot that had dry O rings. How many km on chain Max?
13 DL650 Current ride
80 CX500D
77 XS360
78 XS750
76 CB360T
BC Rider is offline
post #4 of 9 Old 10-23-2019, 10:12 AM Thread Starter
Not too sure on the km as i have tge bike since may. Total km on bike 69000. The rest of the chain looks great... but i think i will chane chain and sprockets. Want to change sizes too...read about that in another thread.
Sent from my SM-N950W using Tapatalk
Brockie and Cryoman like this.
Max in Montreal
2005 DL1000
post #5 of 9 Old 10-26-2019, 10:53 AM
bwringer's Avatar
Yep, time for a new chain.
When one link starts to fail, others are not far behind.
bwringer is offline
post #6 of 9 Old 10-28-2019, 08:56 AM
Agreed. A clicking link means other links may also soon become clicky. Also, the work involved in replacing a single link is probably more work than replacing the entire chain. All the same tools and effort are involved, but when replacing a chain only one link is separated where to replace a single link two pins must be pressed out. Less cursing and potential for problems and busted knuckles involved in installing a new chain.
And as already stated, always replace the chain and both sprockets as a set.
BTF/PTM is offline
post #7 of 9 Old 10-28-2019, 09:49 AM
Motorpsychology's Avatar
And, you will have a known baseline for reference, assuming you don't know the milage of the existing chain or sprockets.
dravnx likes this.
"I never said half of that stuff."-Confucius
Motorpsychology is offline
post #8 of 9 Old 10-31-2019, 07:01 AM
Agreed. When I put a fresh setup on my VFR I discovered that the chain, front sprocket and rear sprocket were three different brands. Definitely gave me a good feeling to remove those variables from the what-if equation. "Of course it's been properly maintained..."
BTF/PTM is offline
post #9 of 9 Old 10-31-2019, 12:05 PM
vanislejay's Avatar
100% backing change the entire chain.
For sprockets, I run 16/43 in traffic and off-road, and I change to 17/43 for long highway miles. The front sprocket is easy to change, about 20 minutes at the side of the road, so if I am doing a mixed on/off road trip, I bring both and swap it when necessary. There is a huge difference in range/mileage with the 16 vs. 17 front.
2003 DL1000
Too much other broken stuff to list
vanislejay is offline
