Adventures in Antifreeze - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 23Likes
post #1 of 23 Old 10-21-2019, 09:40 PM Thread Starter
This pertains to changing the coolant in my 2014 DL650 but I assume it would apply to the 1000 as well.
I put off changing my coolant after watching Dr. VStromís YouTube video on the subject with all of the squeezing, rocking, rolling, wax on, wax off etc. to get all of the trapped air out of the system. While contemplating my fate I became curious to see if you can use a vacuum method (used on cars that are difficult to get the air out of) to fill the system. I rigged up the following system which you may wish to try (or perfect). Italic text is what I wished I had done.
1. I drained the coolant using the conventional method.
2. I rigged up a fill line that attached to the drain port using a rubber inflating tip (used to inflate air mattresses, etc.) with a length of hose attached.
3. I screwed the tip into the port (using some Teflon tape or goo or something to prevent leaks around the threads).
4. Put the hose in a container of coolant (find a 2 liter container so you can put in the entire amount needed- so you donít have to stop and change containers or add more).
5. Disconnect the overflow vent line from the top of the overflow tank (donít forget to empty the tank first). Attach your vacuum pump to this port on the tank (leave the tank cap in place). If you have a real vacuum pump you may want to use a brake bleed bottle in line to catch any coolant pulled out of the system.
6. Now for the trick- you canít evacuate the system with the radiator cap in place so you have to remove the cap and rig it to keep the vacuum relief (metal disk on the very bottom of the cap) on the cap open during this procedure. Take a piece of wire, pry open the disk and wrap the (very short) piece of wire around the disk to keep it from closing (make sure the wire is secure so it doesnít fall off!) and then replace the cap.
7. Take a hemostat (or something) and clamp off the hose going into the coolant. Turn on the vacuum pump and pull a vacuum on the system (will your coolant tank implode? Mine didnít but YMMV).
8. When youíve reached maximum vacuum unclamp the hose into the coolant. The vacuum will suck the coolant into the system (very quickly). (I left the vacuum pump on but in theory you wouldnít need to and you donít with automotive systems).
9. Continue the process until the coolant level comes up into the tank and reaches the fill line (more or less). Then clamp off the coolant fill line again to stop the flow.
10. Now you have to replace the drain plug. Since the radiator cap is ďopenĒ you need to clamp off the overflow line at the radiator to prevent air entering the system (and allowing the coolant to run out). Remove the coolant hose/ tip and re-install the drain plug.
11. With the overflow hose still clamped off, remove the radiator cap, remove the wire and replace the radiator cap.
12. Remove the hose clamp and re-install the overflow tank vent line. Volia!
OK- I didnít do this exactly as I outlined above. When the process was finished, I found that I had put in about 1.6 l (vs. 1.8 normal) of coolant (200 ml short). I put the gas tank back on and rode the bike for about 10 miles. After the bike cooled off, I clamped off the overflow line (to keep the coolant from coming out of the overflow tank, took off the cap (fortunately this can be done without removing the tank). I was able to put in the remaining 200 ml with a piece of hose and a funnel. Even though I wasnít totally successful I didnít have to squeeze, rock, multiple attempts to get the air out.
At this point you may say ďjeez thatís complicatedĒ but it saves a lot of work if you can use it.
Questions or suggested improvements are welcome.
Webfors likes this.
wrightpwx is offline
post #2 of 23 Old 10-21-2019, 09:45 PM
Webfors's Avatar
Thanks for sharing! I've booked marked this page for the inevitable day I either change my coolant, or buy a new bike before I have to.
Motorpsychology likes this.
Two wheelz for realz!
'18 DL1000XT
Webfors is offline
post #3 of 23 Old 10-21-2019, 10:10 PM
Highwayman2016's Avatar
I changed the coolant in my 2014 650 last year and had no trouble with air trapped in the system. So it can be done conventionally without a lot of fuss. Itís been over 10,000 miles so I guess I got it right. Maybe itís just that I didnít read all the horror stories and was ignorant of the problems.
notacop and MPRblue like this.
2014 650 Strom
Highwayman2016 is offline
post #4 of 23 Old 10-21-2019, 10:46 PM
dmfdmf's Avatar
Ditto. No problem with air in the system of my 2014 Wee. I just filled it up and with the radiator cap off, started up and gently rev'd it till the gauge hit three bars then let it cool and then topped it off, closed the cap and connected and filled the reservoir. The next few rides I took it on some twisties for the lean effect which seemed to burp a few bubbles since after it cooled I did have to top off the reservoir but not a lot. Level hasn't moved since.
Stalky Tracker and Skinner like this.
Next Up: ?
dmfdmf is offline
post #5 of 23 Old 10-21-2019, 10:51 PM
Originally Posted by Highwayman2016 View Post
I changed the coolant in my 2014 650 last year and had no trouble with air trapped in the system. Itís been over 10,000 miles so I guess I got it right. Maybe itís just that I didnít read all the horror stories and was ignorant of the problems.
This proves ignorance is bliss. (Lol).
Ratchet is offline
post #6 of 23 Old 10-22-2019, 07:16 PM
TAC PRO's Avatar
Another simple way to make sure rad is filled all the way:
1. With engine off, fill rad to full.
2. With rad cap off, turn on engine and add coolant while engine is running.
3. When rad is full, turn off engine and place cap on rad.
4. Fill overflow container to correct level.
5. Ride.
DesertBike likes this.
Spaling errors and typos have been included on porpoise for those who enjoy finding them.
www.tacpro.com
TAC PRO is offline
post #7 of 23 Old 10-28-2019, 03:55 PM
Onboard Mass Damper
DesertBike's Avatar
As long as we're on coolant...
...can we please get the word around about (lack of) silicates in coolants?
If I have one more shop owner, or supposed professional motorcycle mechanic, try to lecture me about the silicates allegedly present in e.g. Zerex Asian, and how they are "bad" for motorcycle engines...well, I'm going to have cross words with him.
Yeah sure buddy, and I need to change my full synthetic oil every 3000 miles. :/
2007 Vee with too many farkles
DesertBike is offline
post #8 of 23 Old 10-28-2019, 04:58 PM
blaustrom's Avatar
5. Ride.
One more step:
6. Check coolant reservoir level and adjust as/ if needed.
Worked without problems and without adding more coolant on my V2 (2014).
Grimmer and DesertBike like this.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #9 of 23 Old 10-28-2019, 05:49 PM
TAC PRO's Avatar
Originally Posted by blaustrom View Post
One more step:
See step number 4.
www.tacpro.com
TAC PRO is offline
post #10 of 23 Old 10-28-2019, 09:38 PM
STCorndog's Avatar
I do not know about Zerex, but Honda automotive brand of coolant is CLEARLY labeled as non-silicate. I use it.
STCorndog is offline
