Rear wheel bearing seals DL650 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 10-16-2019, 03:38 AM Thread Starter
Hi Guys
I am about to do a chain and sprocket change and thought while I am there will put in the Double sealed bearing.
Have the numbers for them and will go to the local bearing company and get good quality bearings and the seals required.
Sprocket carrier bearings (DL650 all years & DL1000 before 2014):
Size: 32x65x17mm - 1 needed
Common #: 62/32-2RS x 1
Rear Wheel bearings (DL650 all years & DL1000 before 2014):
Size: 20x47x14mm - 2 needed
Common #: 6204-2RS x 2
Can anyone confirm the seals required are 7mm thick, I know the front wheel seals are:
32x65x7mm x 1 and 20x47x7mm x 1
2011 V-Strom 650
A bike on the road is worth two in the shed.
brucestrom is offline
post #2 of 3 Old 10-16-2019, 04:00 AM
Brockie's Avatar
Hi Bruce. "Oil Seal Wheel - 39x65x7 - Suzuki As 09285-39001", for the sprocket carrier, so yes.
"Suzuki 09285-28001 OIL SEAL (28X47X7)" so yes again for the disc side.
These numbers are for 2007-09 DL650 but should cover 2004-11 (if not all 650's).
Happy wrenching.
Brockie is offline
post #3 of 3 Old 10-16-2019, 07:40 AM Thread Starter
Thanks Brockie.
