Footpegs: aftermarket and springs "how to" - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 9Likes
post #1 of 15 Old 08-15-2019, 11:14 PM Thread Starter
outdoorgb's Avatar
So this is my third set of Krator Off-Road style footpegs. Last two sets installed on KLR's. These fit the V-Strom just as well (2009 Wee)
https://www.amazon.com/Krator-FP008-...gateway&sr=8-7
But no springs with these pegs...no problem, lets get some tools and wire and make our own!
"But why do I need springs Mr. Outdoorgb?" Springs make certain your pegs are down when you need them...Up is bad.
Tools: needle nose, channels, fencing pliers (or what ever)...12mm deep socket
Materials: .062" stainless steel weld wire (I use 17-4). Welding shop, get at least two. Heck, grab more. Stuff is useful.
The instructions and pics are for the brake (right) side...same deal for left side but the BIG HOOK around the peg and LITTLE HOOK around the peg mount are mirrored. Read that again, or, since you bought plenty of wire...you'll figure it out.
Put the 12mm deep socket in vice and hold one end with vice grips. Leave about two inches beyond the vice grip
Make four wraps around the socket
Take a look at my pics...put the spring on the peg and see how to bend over the foot peg
Bend it over, trim, file to avoid boo-boos
Now, put that bad boy into the peg mount and put in the pin...don't put the clip back yet
See how the long end of the wire needs to come up and over the mount
Thread this up and use the needle nose to add some spring tension
Pull over and down
Trim and file
Hey, put the clip back onto the pin...
Left side? Rinse and repeat. If my instructions suck, likely, try again with the spare wire you bought, or, Google it...may be a video out there.
Good luck
Gert, drmonbowen and V650 like this.
"This will be the last bike I'll need to buy"...
outdoorgb is offline
post #2 of 15 Old 08-15-2019, 11:17 PM Thread Starter
outdoorgb's Avatar
I was limited on what I could upload...few more pics of finished product.
These pegs are really nice, cast metal. Great foot hold for standing up while riding. No noticeable increase in vibes on the foot...Hell, I run them on KLR's....I know vibes.
Good luck
Gert likes this.
post #3 of 15 Old 08-16-2019, 04:55 AM
Gert's Avatar
Thanx for the pix and write-up. Only last week, I turned a bonnet catch spring for my neighbor's LDV.
Gert is offline
post #4 of 15 Old 08-16-2019, 11:17 AM
vanislejay's Avatar
Have you done this before?
I would think that the non spring steel will just bend when the peg bends up a few times, but keep us posted on this solution please. Good peg springs are hard to find.
2003 DL1000
Too much other broken stuff to list
vanislejay is offline
post #5 of 15 Old 08-16-2019, 12:44 PM Thread Starter
outdoorgb's Avatar
This is my third set. The others are on KLR650's and going strong at 5 and 2 years. No issue with spring degradation. They spring back like day one.
Good point though...Make certain there are four good wraps and the threading up and over are followed.
vanislejay likes this.
post #6 of 15 Old 08-16-2019, 12:53 PM
vanislejay's Avatar
The material you use is like tig filler wire?
2003 DL1000
post #7 of 15 Old 08-16-2019, 12:59 PM
Stainless steel filler rod is not spring steel but it is not mild steel either. it is pretty far from mild steel. 4 wraps of ss filler rod should do what 2 wraps of spring steel do. I have used ss filler rod for other projects.
retired welder here
RLBranson is offline
post #8 of 15 Old 08-16-2019, 01:55 PM
vanislejay's Avatar
retired welder here
Perfect, I will pick some up this afternoon and do this on the weekend. The springs in my pegs are completely shot, and I'm leaving on a big trip with lots of offroad in a couple weeks so this is perfect timing!
cjever19 likes this.
2003 DL1000
post #9 of 15 Old 08-16-2019, 01:56 PM Thread Starter
outdoorgb's Avatar
Yup...17-4 wire or, SS.
.062" in diameter
Interesting point on using spring steel wire. Googled that and it's out there. But I haven't had any issues with the stuff I'm using.
Gert likes this.
post #10 of 15 Old 08-17-2019, 03:52 AM
Gert's Avatar
In my case, I made use of a recovered spring steel, from an old box magazine. That's an interesting tip, making use of a stainless filler rod. Something to keep in mind, if no spring steel on hand.
For info, piano / music wire makes the best springs.
Gert is offline
