Found the source of a rattle (in case this helps anyone with the same problem) - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 6Likes
  • 2 Post By Goneriding
  • 1 Post By Dubldee17
  • 1 Post By RestoRider2017
  • 1 Post By 406RIDER
  • 1 Post By Webfors
post #1 of 9 Old 08-04-2019, 11:28 AM Thread Starter
Picked up a brand new '18 650 and have been hearing a metal rattle while in the lower end of a 2nd gear. It was this darn plate (see pic) that wasn't tightened properly (took a while to figure it out so sharing in case anyone else has a similar issue).
Cheers
Webfors and EddieFL like this.
Goneriding is online now
post #2 of 9 Old 08-04-2019, 12:30 PM
Suzuki says to tighten to 10N-m, 7.5lb/ft. Possibly left undone following the fuel pump o-ring recall. Better give it a good going over to be sure nothing else got left loose. DD
Goneriding likes this.
Dubldee17 is offline
post #3 of 9 Old 08-04-2019, 02:48 PM
I had a rattle that I could hear on my GoPro audio. Couldn’t figure out where it was coming from. Eventually found the rubber grommet under that plastic cover was gone so the cover was rattling against that bracket. Who knows where that stupid grommet went...
2015 V-Strom 650XT ABS
1969 Triumph Bonneville
EddieFL is offline
post #4 of 9 Old 08-05-2019, 12:34 PM Thread Starter
Thank you very much for this! Yes they confirmed a recall on the o-ring was done.
The front axle pinch bolt was also barely screwed in. I'll call them with a few well crafted words tomorrow and drop the bike off at my trusted mechanic for the first service. Lesson learned to check and double check myself.
Thanks again!
post #5 of 9 Old 08-05-2019, 05:39 PM
RestoRider2017's Avatar
Location: Apopka Florida NW of Orlando near a twist in the road and a hill on the horizon...
I have similar horror stories about my service to get the oring recall done. Stupid tech put stuff together
backwards and left loose. I rode the bike home only to have to take it right back to the dealer to be fixed
again. They had to take parts from a new showroom bike to replace the ones this A hole screwed up.
He no longer works there. My dealership is absolutely terrible. When my extended warranty is done
I'll be doing all the service work myself.
EddieFL likes this.
2017 DL 650 , Shad 23 bags, Givi crash bars, 32 watt LED aux lights , Goldwing pegs, Metalic silver front fender, Lazer cut aluminum Chain guard, Madstad 20" windshield
light smoke tint , Blu/blk Driven Racing Billet bar ends, Dbl Take adventure mirrors , BeadRider Ceramic bead seat cover,
Stock exhaust for now. Yoshimura 3/4 system simmering on low in the oven.
Avatar image is a custom made Harley Sportster all hand built from junk parts from a retired engineers desk. Took 80 hours to make.
RestoRider2017 is offline
post #6 of 9 Old 08-05-2019, 09:56 PM
I really hate to hear this kind of stuff, as I spent some years as a dealership mechanic. I really want them to be better, but there just aren't any guarantees anymore when you take your bike in for service. Nobody's perfect, I'm certainly not even close, but it seems we worked harder to get it right. There is simply no excuse for not following factory procedure. Also no excuse for the service manager not overseeing his techs.
I had a lengthy discussion with the service manager at my dealer regarding this recall. I don't want somebody doing this work on my bike knowing they're under the gun to get it done at flat rate. I even asked if I could just take the tank in, no dice. I'm going to buy the kit and do it myself, and keep throwing the recall notices away. I've got all day and a clean padded work area. No sign of leakage anyway.
I'm glad you caught this screwup before you got hurt. If you don't already work on your own stuff, this might be a good time to start. Make a habit of checking critical fasteners. Enjoy your new bike. DD
post #7 of 9 Old 08-13-2019, 10:18 PM
In my case the service manager was involved in the re-repair the second time around.
Because when I explained to him on the phone what I found when I took the seat off he
fired the tech that worked on my bike.
The rear rubber Isolator for the tank mount was never installed and was stuffed down on top of the battery.
Rear tank bolt loose.
The front bracket that holds the tank down with 2 smaller bolts was installed backwards and 1 of the bolts
was completely broken in 2 pieces. It had to have an easy out to get the thread area out.
Second time around I watched everything they did for the entire hour the bike was in the shop.
They knew I was pissed. After - Everything was fine- no issues since.
post #8 of 9 Old 08-13-2019, 10:48 PM
Purchased my bike new in 2016. On the second short ride I came to a stop and the front brakes felt soft. Then the RT brake caliper fell off. Yep, one bolt missing and the other fell on the ground right there at the intersection. Good thing it didn't happen when I really needed the brakes. Went back to the dealer and we had a conversation. They said 10 days for new bolts. I said go to the warehouse and pull the bolts from another new bike. I went home with the bolts. I got out my torque wrench and checked all critical fasteners.
Solo likes this.
current ride
'16 DL650
previous rides:
'09 Buell Ulysses
'05 HD Dyna SuperGlide Custom
'08 Suzuki Bandit 1250ABS
'01 HD ElectraGlide Std
'90 HD ElectraGlide Sport
'80 HD WideGlide
'80 Suzuki GS850L
406RIDER is offline
post #9 of 9 Old 08-14-2019, 08:15 AM
Webfors's Avatar
Thanks for sharing. Threads like this are why I love this forum. Knowledge, knowledge, knowledge
Big B likes this.
Two wheelz for realz!
Webfors is offline
