Leaking injector sanity check - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By Ryman12
post #1 of 5 Old 07-26-2019, 07:40 PM Thread Starter
Hi guys,
About three weeks ago I purchased an 09 dl650, ran great no issues. Last week the temperature was well over 90 degrees, and my bike was parked in the sun for about 10 hours, leaving work I went to start the bike and it fired up but the second I gave it any gas it stalled. After sitting in the shade for about 20 minutes (is was in the evening so the air temp was also dropping) and dumping in a bottle of STP fuel treatment (I had just filled up and figured I might have gotten some bad gas) it ran normally.
Fast forward to last night, and I begin to hear a tapping noise which I first passed off as noise from a bad chain. But as time went on it was clearly coming from the front cylinder. I checked the sight glass and it was beyond full. Smelled the oil, and yep, gas.
So I suppose my question is, the most likely culprit would be a leaky injector correct? Is there a gas tank vent that might be clogged causing the pressure in the tank to force gas past the injector? Im hoping that if I swap in good injectors and change the oil I can at least get a few thousand more miles out of this engine before its toast.
Thanks for your help!
Ryman12 is offline
post #2 of 5 Old 07-26-2019, 11:47 PM
Rolex's Avatar
What part of the world are you in ?
You should put that into your profile to get the best help
Different places can get slightly different fuel systems on their bikes.
Also remember every time your fuel pump primes it will produce pressure, if you have a leaking injector that pressure will flood fuel into the cylinder.
A good indicator of a leaking injector is the bike will require the throttle opened to start after a short stop as there will be excess fuel and a lack of oxygen in the cylinder.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #3 of 5 Old 07-27-2019, 04:34 PM Thread Starter
Thanks for the input Rolex! I live in Colorado. Im hoping that changing the injectors and oil will fix the problem for now. Hopefully too much long term damage hasnt been done. Finger crossed!
Rides likes this.
Ryman12 is offline
post #4 of 5 Old 08-17-2019, 06:46 PM
Rides's Avatar
I had leaking injectors. A $25 ultrasonic cleaner and $15 injector tester plus a rebuild kit and they are working great now.
You can also send them out to be rebuilt for not much.
It’s amazing how much material comes out of the injectors in the ultrasonic bath.
Rides is offline
post #5 of 5 Old 08-18-2019, 04:26 AM
Gert's Avatar
The following links are the Vee injectors, but it will apply to the Wee as well. Have you read https://www.stromtrooper.com/dl1000-...y-pattern.html and https://www.stromtrooper.com/dl1000-...unt-time.html? Do take note of the warning in post #5 of the second link, when testing the injectors.
Gert is offline
