Charging Issue - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 07-26-2019, 11:57 AM Thread Starter
Charging Issue
On a 2006 DL1000 what is the highest voltage i should be seeing at 4 or 5000 RPM? My bike is showing in the low 15's. The battery has been dropping down to 10 or 11 volts after riding 2 to 3 hrs straight and will not start after that. Everything has been checked and rechecked and all the numbers are right and there is no draw on the battery from any aftermarket products. Could the regulator be bad? The bike only has 7000 original miles also.
Thanks.
Peterz
peterz56 is offline
post #2 of 5 Old 07-26-2019, 01:19 PM
RoadWarrior1978's Avatar
13.5 - 14.5 is the norm, no more. I would say that the regulator is at fault, however the stators are known to fail and in your case I would say it's well worth investigating the output of each phase to ensure everything is as it should be, the low battery voltage is odd given the high charge voltage you stated.
The battery could also be done, so may as well double check that too.
It's not yellow, it's "YELLOW!!!!"
RoadWarrior1978 is offline
post #3 of 5 Old 07-26-2019, 01:40 PM
Originally Posted by peterz56 View Post
On a 2006 DL1000 what is the highest voltage i should be seeing at 4 or 5000 RPM? My bike is showing in the low 15's. The battery has been dropping down to 10 or 11 volts after riding 2 to 3 hrs straight and will not start after that. Everything has been checked and rechecked and all the numbers are right and there is no draw on the battery from any aftermarket products. Could the regulator be bad? The bike only has 7000 original miles also.Peterz
I would advise three checks: the battery, the R/R and the stator. Take the battery to Advance Auto or its equivalent in your area and have them do a load test. Unlikely it is the battery, but it may have been damaged if the 15 volts is a correct reading. If the battery is dead, they'll charge it and then test it. For the stator and the R/R tests, there are multiple threads here and lots of Utube videos. These tests are easy with your multi-meter.
You mention that "Everything has been checked and rechecked and all the numbers are right"... but I'm not sure what you mean by that.
Yarz1 is offline
post #4 of 5 Old 07-26-2019, 06:13 PM
Rolex's Avatar
On that bike there is a huge chance the magnets have moved this will give unusual readings.
What are your readings at other RPM's ?
When testing for voltage you should also test for AC volts at the battery, if you find AC volts the regulator has had better days.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #5 of 5 Old 07-26-2019, 09:13 PM Thread Starter
Thank you.
peterz56 is offline
