Tip for those with rough running bikes - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
  • 3 Post By Dark Angel
post #1 of 4 Old 07-17-2019, 01:33 AM Thread Starter
Dark Angel's Avatar
Since getting my K9 I've had intermittant rough running issues on top of my fuelling issues. The fuelling was the dreaded high pressure filter as well as a clogged and collapsed pickup screen, both of which I'm blaming on the bike being left sitting with garbage (ie ethanol) fuel for extended periods before I got it (under 10,000km when I got it not long ago), but the rough idle just didn't fit that cause. After replacing the filters etc (bypass next time) I went hunting and found this:
The little rubber tit off the end of the vacuum take-off port has been gnawed on by a little grey bastid (mouse most likely) and is passing air, throwing the whole thing out of balance. I had some spares in my parts box for my BM that fit, but if people are struggling to sort out balance issues, make sure to check these.
vegashotwheeler, chicago and Gert like this.
Dark Angel is offline
post #2 of 4 Old 07-17-2019, 07:22 PM
RestoRider2017's Avatar
Location: Apopka Florida NW of Orlando near a twist in the road and a hill on the horizon...
Thats great that you showed us this because even the small things like this cause issues and are very hard to spot
unless you know where to look.
2017 DL 650 , Shad 23 bags, Givi crash bars, 32 watt LED aux lights , Goldwing pegs, Metalic silver front fender, Lazer cut aluminum Chain guard, Madstad 20" windshield
light smoke tint , Blu/blk Driven Racing Billet bar ends, Dbl Take adventure mirrors , Gel seat cover, Twin tool tubes, Givi 30L top case, 45 years in the saddle and counting
Yoshimura 3/4 system simmering on low in the oven.
AMA member, RestoRides MotorSports CEO
Our dog Trixie 7 year old Chiuaua / Min Pin mix Shelter Rescued Smartest dog we have ever owned. She's great and does lots of tricks.
RestoRider2017 is offline
post #3 of 4 Old 07-17-2019, 08:22 PM
Stalky Tracker's Avatar
Good tip, Dark.
I found mine were cracked when I went to put extension tubes on for easier throttle body sync'ng. I think I found four, if memory is correct, and all were cracked or split on the ends.
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
post #4 of 4 Old 07-17-2019, 10:27 PM Thread Starter
Dark Angel's Avatar
Also, be careful when you remove them. I managed to flick one off into the aether where it's been hiding ever since along with it's clip. Bit of a pain, really. Mine also has hoses on the other two ports which I haven't traced yet as they don't seem to be giving me any grief.
