Since getting my K9 I've had intermittant rough running issues on top of my fuelling issues. The fuelling was the dreaded high pressure filter as well as a clogged and collapsed pickup screen, both of which I'm blaming on the bike being left sitting with garbage (ie ethanol) fuel for extended periods before I got it (under 10,000km when I got it not long ago), but the rough idle just didn't fit that cause. After replacing the filters etc (bypass next time) I went hunting and found this:
The little rubber tit off the end of the vacuum take-off port has been gnawed on by a little grey bastid (mouse most likely) and is passing air, throwing the whole thing out of balance. I had some spares in my parts box for my BM that fit, but if people are struggling to sort out balance issues, make sure to check these.
