1000 clutch push rod seal secret? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 13Likes
post #1 of 17 Old 06-17-2019, 12:35 PM Thread Starter
CoastyAV8R's Avatar
I've replaced the clutch push rod seal on my 08 1000 and its slight a drip. I read the thread on how to replace it but I'm curious what's the secret as obviously I missed something. I cleaned the beejezus out of the seal area prior to install. Do you guys use any type of sealant or something more exotic such as the blood from last white rhinoceroses? I have another new seal I'm going to swap out today but before I do I wanted to draw on some of the forum's wisdom.
Thanks in advance...
2008 V-Strom 1000
CoastyAV8R is offline
post #2 of 17 Old 06-17-2019, 01:24 PM
V-Tom's Avatar
I don't know of any secrets although I think, like the factory oil filter seal, giving the seal a little wipe with oil is a good idea and make sure it doesn't go in too far.
..Tom
Big B, Gert and Webfors like this.
My Opinion:
Vee or V= DL1000 before 2014
Vee3 or V3 = DL1050 2020 to?
My Stroms:
SMIDSY detailed report.
V-Tom is offline
post #3 of 17 Old 06-18-2019, 04:19 AM
Gert's Avatar
You could try a bit of wheel bearing grease, where the clutch push rod goes into the seal. Also make sure that the push rod seal sits flush with the casing and not below the casing surface.
Gert is offline
post #4 of 17 Old 06-18-2019, 05:34 AM
Hello,
I just bought a 2008 DL1000 a month ago that had just under 8000 miles. It developed a small leak where the clutch push rod seal is.
My first two attempts ended in failure. Third time was a charm. First time I followed the advice of a sticky posted on here that recommended using a thin layer of food grade silicone grease ( like plumbing grease ) around the contacting surfaces of the seal. That was a bad idea. Second attempt failed because I tried to reuse the new seal again. Third attempt ... I made sure all the oil was drained completely so there was no oil pooling up behind the seal. I used alcohol, q-tips and a very clean rag to make sure everything was spotless. I decided to use Honda-bond 4. I put a thin layer around the outside edges of the seal, waited 24 hours. I than took a very small paint brush and applied a thin layer of the Honda-bond 4 around the outside edge of the seal and case, waited another 24 hours. I also decided to replaced the clutch rod. In the factory service manual Suzuki recommends using Suzuki Super grease, an inch on each end of the rod. ( A little lite weight type of grease is probably fine.) Success ! So far so good ! No sign of any leaks ! It's been about 50 miles with a couple of heat cycles, high revs and hard riding.
I literally called 10 Suzuki dealerships to get an opinion from various service departments. Each one had a different opinion about installing those push rod seals.
A couple dealers said do it dry, A couple dealers said use sealer, A couple dealers said use grease, One dealer said use contact cleaner to lube the seal, push it in and it will dissipate.
The Honda-bond 4 is very sticky and can be messy if not careful.
DesertBike likes this.
2008 Silver DL1000
Fork Brace
WERKS Clutch Basket
Super Bright 5600K LEDS
Continental Attack 2 Tires
Power Commander III
GIPro Gear Indicator ATRE
GP Kompozit Windshield
Mirror Extensions
OEM Center Stand
Galper Front Sintered Brake Pads
Galper Steel Braided Front Brake Lines
SV Racing Big Brake Adapter Kit
Nissin Gold 4 Piston Front Calipers
( From 2003 Honda CBR 954 RR Fireblade )
Maxima 10/40 PURE Synthetic Oil
Staintune Slip-on Mufflers
Shindengen SH847 Serial R/R
Garagedoorman is offline
post #5 of 17 Old 06-18-2019, 10:50 AM
Onboard Mass Damper
DesertBike's Avatar
Wonder if Permatex RTV gasket maker would work here? I have a tube of their Ultra Black RTV product, which is especially rated for oil resistance - seems appropriate, given the location of this seal.
Garagedoorman likes this.
2007 Vee with too many farkles
DesertBike is online now
post #6 of 17 Old 06-18-2019, 12:47 PM
Good question. I can tell you the Honda-bond 4 is a lot stickier and dries to the touch faster and cures better.
I tested two old seals. I applied around the outside of each seal. The Permatex RTV Ultra Black peels off even after 24 hours. The Honda-bond 4 does not peel off after 4-5 hours let alone 24 hours..
2008 Silver DL1000
Fork Brace
WERKS Clutch Basket
Power Commander III
Mirror Extensions
OEM Center Stand
post #7 of 17 Old 06-18-2019, 12:59 PM
Onboard Mass Damper
DesertBike's Avatar
I believe that's intentional - the peeling off ability I mean. But likely unimportant on a seal you're going to replace anyway.
I don't know if I'm just super lucky or what, but my original pushrod seal is still A-OK at ~47000 miles.
post #8 of 17 Old 06-18-2019, 01:26 PM
I just bought my 2008 with 7996 miles a month ago. It started leaking on the side stand. I figure at 697 miles a year the V I bought wasn't ridden a lot. I attribute my leak to the bike sitting around mostly.
It's my thoughts that the Honda-bond 4 provides a better seal or bond. Time will tell. So far so good.
To answer the Op's question: " Do you guys use any type of sealant or something more exotic such as the blood from last white rhinoceroses? "
I think Honda-bond 4 is that sealant.
2008 Silver DL1000
Fork Brace
WERKS Clutch Basket
Power Commander III
Mirror Extensions
OEM Center Stand
post #9 of 17 Old 06-18-2019, 01:47 PM
Onboard Mass Damper
DesertBike's Avatar
Yikes, only 8000 miles on a 2008 is a crime.
My 2007 had a hair under 22k when I bought it in 2016, so at least someone was enjoying it now and then. Amongst all the owners so far, I'm the only nutjob who's insisted on riding year-round.
post #10 of 17 Old 06-18-2019, 02:11 PM
The original owner developed a bad back, so he couldn't ride anymore. I was happy for the low miles, not happy when it started leaking.
Leak fixed, added some farkles and it's running good so I'm happy now.
These bikes are made to be ridden, You're putting yours to good use, thats awesome. I may not ride in the rain if I can help it but I want to put my V to good use. It's a blast to ride.
I hope the OP has good success with his seal change out.
2008 Silver DL1000
Fork Brace
WERKS Clutch Basket
Power Commander III
Mirror Extensions
OEM Center Stand
