remove pin from mitsu ultra compact connector - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
post #1 of 12 Old 06-16-2019, 01:50 AM Thread Starter
chikosneff's Avatar
Exclamation remove pin from mitsu ultra compact connector
Hey, guys, I am replacing my front turn signals and I need to disassemble the Mitsubishi ultra compact 2 pin connector. I cannot understand how the tab mechanism locking the pin works. I got one out but I just got lucky, I cannot get the second to move. Suggestions? Thanks!
chikosneff is offline
post #2 of 12 Old 06-16-2019, 03:46 AM
Gert's Avatar
Not sure what the connector looks like any more, but why don't you snap a few close-up pix of both ends of the connector that you have managed to remove? From these pix you should be able to determine where the tabs are located and how they are to be operated / pressed to remove the connector. Sometimes it is a matter of brute force once the tab locks have been freed.
Gert is offline
post #3 of 12 Old 06-16-2019, 04:10 AM
Usually a pin does it. There's usually a tang that pops up to lock them when inserted, slide a pin down the back, push that tang down and pull the pin out.
PeteW is offline
post #4 of 12 Old 06-16-2019, 04:14 AM Thread Starter
chikosneff's Avatar
This is how the connectors look
https://www.easternbeaver.com/Main/E.../mitsu_uc.html
I have done a ton of other styles with no trouble I do not understand why these are giving me such a hard time...
post #5 of 12 Old 06-16-2019, 06:29 AM
Jewelers screwdriver sets usually come with a very small option. If a pin doesn't work the smallest screwdriver usually does.
PeteW is offline
post #6 of 12 Old 06-16-2019, 11:17 AM
At work we had a pin install/extract kit that made working on those things easy. Until some weasel mechanic pilfered it at hid it in his tool box. Stinking fink.
Then we had to make do with small screwdrivers or make our own tools.The round pins were the biggest bother. We had to find a bit of metal tubing to do the job.
notacop is online now
post #7 of 12 Old 06-16-2019, 12:37 PM
I did it once and there is a trick to it. It was a while back, I can't remember all the details but I made up some kind of a probe to release the "barb" holding the pin.
Not sure if this thread will help https://www.stromtrooper.com/mainten...rn-lights.html
If I have time today I will investigate further and get back to you.
gdrew is offline
post #8 of 12 Old 06-17-2019, 03:28 PM Thread Starter
chikosneff's Avatar
Thanks if you can remember what was the trick I am all ears. I disassembled all kinds of electrical connectors and these little ass****s have been the most challenging so far. I somehow succeeded in removing one of the pins but I destroyed the other in the process ...
post #9 of 12 Old 06-17-2019, 04:14 PM
I'm sure I had taken pictures of what I was doing when removing the pins and of the tool I made in case I needed to do it again. I'm pretty sure the Photobucket fiasco ended my access to those pictures if indeed that's where I put them. I'll keep looking...
I think the tool I made was a 2 inch nail ground flat on two sides. The real trick is to figure out which end and side to go at it from. If you have one apart already, take a close look under magnification to see if it reveals any clues. Once figured out its so easy you're going want to slap your own forehead...
chikosneff likes this.
gdrew is offline
post #10 of 12 Old 06-20-2019, 03:31 PM Thread Starter
chikosneff's Avatar
I mangled up one of the pins while removing them from the connector so I ended up having to buy new connectors online.
If anybody has a picture of the extracting tool I think that would be very helpful for future reference.
Thanks for all the replies.
