2015 DL650 Steering Bearing Replacement - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 41Likes
post #1 of 39 Old 05-25-2019, 09:36 AM Thread Starter
Webfors's Avatar
Howdy all,
started to get the ugly wobble on deceleration. Can't take my hands off the bars for longer than a couple of seconds without a tank slapper event.
Reading over several threads it appears that I need to replace the stock bearings with tapered bearings, packed with grease.
Are there any howtos for this? Any suggestions on parts, tools, tips or links would be appreciated.
Two wheelz for realz!
'18 DL1000XT
Webfors is online now
post #2 of 39 Old 05-25-2019, 09:55 AM
https://blacklabadventures.com/
Might be what you are looking for here.
You may try just adjusting the steering head first.
My 04 Wee is a bit notchy in the middle of the swing but it has nearly 100K miles on it.
Tire choice can make a difference too. There has been some discussion about that going back some years.
post #3 of 39 Old 05-25-2019, 10:17 AM Thread Starter
Webfors's Avatar
Looks like I need a set of 32006 tapered roller bearings. A quick search on ebay provides a lot of options.
https://www.ebay.ca/sch/i.html?_from...rings&_sacat=0
A quick google search reports SKF and NSK as reputable brands. Is there any specific brand/model in the ebay list that you would choose?
Next I'll need a tool for the head. Looks like a lot of options for that also:
https://www.ebay.ca/sch/i.html?_odkw...+tool&_sacat=0
Any recommendations on which tool to buy?
Lastly, I'll need a tool to install/compress the bearing into place. I'm not sure what to search for, or if a tool even exists for this. Looking over some threads people have used PVC piping, with modifications, for this job.
'18 DL1000XT
post #4 of 39 Old 05-25-2019, 10:18 AM Thread Starter
Webfors's Avatar
Thank you! I read through it. Good write up. I assume it's the same for the 2015 wee?
'18 DL1000XT
post #5 of 39 Old 05-25-2019, 10:21 AM
It should be similar. I used this info when doing my 04 Wee and realized the fork was almost exactly like the fork on my '76 BMW 750/6. The science hasn't changed much except for the upside down design but even then the overall function is the same.
post #6 of 39 Old 05-25-2019, 10:33 AM
dravnx's Avatar
If the bearings don't feel notchy, they don't need replacing. Check to make sure the bearings are not too loose either. Try adjusting first and see if that fixes it. If not, replace your front tire and make sure it's balanced. Do one thing at a time. The basic rule of troubleshooting. I pulled the following from another forum and it describes a good procedure for adjusting your steering head. The poster owns a motorcycle repair shop.
STEERING HEAD BEARINGS 101
If your steering head bearings are too tight the bike will weave and
not seek it own center... if you're steering head bearings are loose
you'll notice a pronounce clunk during braking...
I don't use a torque wrench because it lacks feel rather I raise the
front wheel off the ground and tighten the steering head bearings
until the bars lock then I back off the nut until the bars free wheel
with a slight drag... with this method you'll find that sweat spot and
avoid over tightening and under tightening even if you upgrade to
taper roller bearings...
Webfors likes this.
L2 DL650 Adventure
bike X miles=smiles
smiles bike=miles
smiles miles=bike.
It's simple math.
https://www.directavionics.com/
dravnx is offline
post #7 of 39 Old 05-25-2019, 11:11 AM
Mulewright's Avatar
While I agree that the bearings should at least be checked & adjusted properly, from what you describe It sounds more like a front tire issue.
I have ran into this with a couple of brands. Replacement fixed it right up.
[B][I]~ Stretching the Limits of Performance & Good Taste ~[/I][/B]
Mulewright is offline
post #8 of 39 Old 05-25-2019, 06:44 PM
The stock bearings are a known issue. Upgrading to rollers is a good move. I'll do it when I reach 40k miles. Here are my notes if it helps:
head upgrade
SKF Tapered roller bearing 32006 - 2 needed
Seal #: 51644-12C00 - 2 needed
DL1000 or DL650 Steering Stem Socket Wrench DHS-4131-1 $35.00
Big B and Webfors like this.
Hatchi is offline
post #9 of 39 Old 05-25-2019, 07:19 PM
That big wrench is neat and may allow for more precise adjustment but I bet a pair of water pump pliers would do the same thing.
The bearings are just like a bicycle. As a kid i didn't have any fancy tools and have done adjustments on motorcycle using a drift punch and a hammer on the edge of the recesses of the nut.
I do admire the brave mechanics who made their own version of the commercial ones. might be easy with a mill but a workout with a file set.
But the $35 for the tool vs the couple hundred $ a shop would charge is minimal investment.
post #10 of 39 Old 05-25-2019, 09:32 PM
TAC PRO's Avatar
If you're installing tapered roller bearings, you will need a bearing shim. Suzuki part number 09181-30184-000.
The shim goes between the lower steering head grease seal and the lower steering head bearing. The shim raises the bearing slightly to prevent the grease seal from grabbing the outer edge of the bearing and causing drag. If this shim is not installed, the steering will be stiff as if the bearings are too tight and cause the bike to wander at slow speed.
Adjusting the OEM bearings will likely stop the low speed wobble.
notacop and Webfors like this.
Spaling errors and typos have been included on porpoise for those who enjoy finding them.
www.tacpro.com
TAC PRO is offline
Steering head bearing surprise! g6snl DL650 and DL650A - 2004 to 2011 16 03-15-2018 03:06 PM
Fork Seal Replacement - DL650 Boondocker V-Strom Service and Maintenance Questions and Discussions 21 03-20-2017 05:56 PM
Steering head bearing woes McRuss DL650 and DL650A - 2004 to 2011 4 08-10-2014 06:30 AM
