What is the deal with Tank Bags? - Page 7 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 70Likes
post #61 of 76 Old 06-03-2019, 08:13 PM
scab's Avatar
Originally Posted by ERockJL View Post
This thread is going to make me spend money
Uh, yeah, it did. I placed an order for the Givi with tank lock ring from our supportive friend at Adventuretech. Then as I complete the order, I see the fork brace slide by the screen on the scrolling Adventuretech site. Dang it, placed another order.
DesertBike likes this.
If you're not living on the edge, you're taking up too much space.
scab is offline
post #62 of 76 Old 06-03-2019, 09:01 PM
Originally Posted by realshelby View Post
You have to undo at least some of the straps. Move the bag to the rear, tilt to the front, or fold over the side. Quite cumbersome compared to a tank ring lock bag.
Realshelby, I know you are one of the senior contributors here, but I don’t understand where you are coming from with this statement. Did you ever own a good quality one like a Wolfman? It takes me two seconds to undo the two top buckles right under the handlebar, and another second to flip the bag upside down onto the tank. It’s a total non-issue! I’ll take a video next time I buy gas and post a link here.
realshelby and Spec like this.
Hogges is offline
post #63 of 76 Old 06-03-2019, 09:10 PM
Originally Posted by DesertBike View Post
How do those strap-on bags work when you're getting gas? Do you just sort of push them aside, or do they have a divot in them so you can get to the fill cap, or what?
My Wolfman has snap buckles all around. Four of them. About the same kind and size you might find with a chest strap on a backpack. Undo the two front ones, leave the rear ones alone, flip bag over onto seat, upside down. When done just click the buckles back together, the straps are already the correct length. Or give them a tuck every once in a while so everything is where it should be. Hope this helps. I have the Explorer Lite.
Spec and DesertBike like this.
Hogges is offline
post #64 of 76 Old 06-04-2019, 08:00 AM
Originally Posted by Hogges View Post
Realshelby, I know you are one of the senior contributors here, but I dont understand where you are coming from with this statement. Did you ever own a good quality one like a Wolfman? It takes me two seconds to undo the two top buckles right under the handlebar, and another second to flip the bag upside down onto the tank. Its a total non-issue! Ill take a video next time I buy gas and post a link here.
Well, I am a Senior! I go out of my way to give reports that are unbiased and based on facts as I have learned them. Which doesn't go over well sometimes.
Yes, I have owned at least 3 strap type tank bags. Two magnet type tank bags that I remember.
I will never, ever even consider a magnet tank bag again.
One of the strap bags was rather large, I don't remember the brand for sure but it was a Nelson Rigg or Wolfman. Been 10 years or more that I gave it away. Not because it didn't work well, but was simply too large. The strap on tank bag that I still have, and would not hesitate to use again if needed, is a Nelson Rigg. On the smaller side of average. Many miles on it. It is what I used up till I went with the tank lock bags. It has the nylon buckles you squeeze to release. Two up front, one in the rear. I know it doesn't take too much effort to release the buckles....
I can have the Givi tank lock bag released and set in front of the handlebars before you get the second buckle loose. Givi tank lock bags are that easy to use. I also run a tether, optional, that I do not have to release unless I take it in with me.
Common sense tells you that no matter how careful you are, strap on bags are going to have a chance of scratching the paint or rubbing places in trim or paint. Ride a week in rain and if you don't clean under it often, there WILL be scratches from the rain water that has grit in it.
All strap on bags need you to fit and secure the tie down straps to the frame or other secure mounting point. That isn't too hard, but I will bet that many owners just leave them on the bike. I did on my BMW as getting them on and off was a bit of a hassle. When the bag is off, are the straps flopping in the wind? Maybe they need secured, another task. I don't run the tank bag unless I am traveling, so the straps are not welcome when I ride locally without the bag.
Probably the biggest reason I don't use a strap on bag, once I finally spent the money on a tank lock, is that I don't like to move my bag onto the seat. When travelling I usually have gear on the passenger seat. Then when I stop for fuel I sometimes remove my helmet, which I always put on my seat. No room for the bag there then. What I normally done was loosen all three buckles to put the bag away from the tank, or sometimes loosened to the two front ones and let it dangle to the side off the rear buckle. Worked out ok.
But again I can flip the lever on the Givi with the hand I grab on the right side with and lift it up and over the bar to set between the bar and dash. I will bet I can have it in place quicker and easier than you can undo the strap type buckles up front. Then you still have to move it around.
So while you have a good way of tending your bag by flipping it over, that isn't what I want to do with mine. I really don't want my bag turned upside down, due to what I carry in it. That is personal preference.
Negatives of a tank lock bag? Well you do have to leave the tank ring in place. But I hardly notice it. Cost? Yes you will pay more for a tank lock bag. Security? Well, I do run a tether on mine. But I have never had it come loose. ( I can tell you that I have forgotten to insert the buckles bag into the strap bag more than I want to admit!)
It is soooooo much easier to just plop the tank lock bag in place and snap the tether. No hunting for straps. I will go out on a limb here and say that anyone that buys a tank lock system will never want to have any other style. There is simply NO comparison in how convenient they are to use!
realshelby is offline
post #65 of 76 Old 06-04-2019, 08:21 AM
Here is the challenge. I made a video of releasing and reattaching the Givi tank lock bag. One shot of this, no practice. This is EXACTLY as it works when I stop for fuel. Can you match this with a strap on tank bag?
68hoosier, DesertBike and EddieFL like this.
post #66 of 76 Old 06-04-2019, 09:34 PM
What I liked about my tank lock Givi, was being able to swap it, instantly between my DL650 and my ST1300. No straps to adjust and no scratchin' magnets.
realshelby and DesertBike like this.
2018 Goldwing DCT Tour
2013 V-Strom 650
Nashcat is offline
post #67 of 76 Old 06-04-2019, 09:50 PM
scab's Avatar
I feel even better about my order.
scab is offline
post #68 of 76 Old 06-04-2019, 11:06 PM
Macdoc's Avatar
Teeny tiny tank bag and you are standing beside the bike with no gear on.
Try pulling a fully loaded bike up to fuel up without getting off the bike and with a 20+ liter tank bag. My Nelson-Rigg expands to 27 liters and I don't need to fiddle with some latch underneath and it was an empty bag ...mine is stuffed and often clocks in at 10-12 lb.
I just lift the bag off, set it vertically by my boot. Fuel up without ever getting off the bike...plant the tank bag and gone.
Magnets rock and what are you doing on an adventure bike if a couple scratches bother you??..
and magnets generally work on most bikes so swapping is not an issue. Gets expensive if you buy lock rings for different rides.
Mine works fine on my CB500x or the KLR650 and my previous 20 liter went everywhere on the Vstrom and then on the CBf1000.
I don't like the fact that the tank bag rings limit where you can position the bag.
Canada 2018 CB500x >2009 CBF1000 sold 10 Wee ABS sold 09 Burgman Exec sold 10 NT700v sold
Australia> 04 KLR650 93 ST1100 sold
Macdoc is offline
post #69 of 76 Old 06-05-2019, 09:37 AM
Onboard Mass Damper
DesertBike's Avatar
I don't want to fiddle with either straps or magnets, so tank lock ring it is.
What annoyed me about the magnetic Manta bag was not so much the inevitable paint damage, but the sheer annoyance of pulling it off every gas stop. The quick lock deal is just easier and faster.
Also the Manta had no built-in carry handle. Sounds like a small thing but it ain't. That's more about that particular bag than magnets though.
To each his own, but I don't want to fuel while sitting on the bike. Seems risky at best, if not downright foolish, and I am never in THAT much of a hurry.
I stayed on the bike while gassing up exactly once. The pump malfunctioned, and suddenly the tank was overflowing. I probably set a speed record, manually stopping the flow, hopping off the bike, and finding something solid to hide behind. I was convinced I was about to watch a big fire happen, as soon as the spilled gas touched a hot engine part.
Eventually the extra gas evaporated, and everything was fine, but I'm not doing that again.
Would that I were so fortunate as to have a multiple bikes problem. For those that do, the Givi ring adapters are around $16. BFD.
Still working on the prototype adapter to shift the bag back a little. Got hardware yesterday. I'm sure hijinks will ensue when I try to connect stuff up.
Some of the larger (>5L) quick lock bags do have provisions for shifting the bag forward and aft to suit. It's mostly the really small ones (like mine) that don't.
2007 Vee
DesertBike is offline
post #70 of 76 Old 06-05-2019, 05:26 PM
I don't own a tank lock model but I have to say my bag is not cumbersome at all. Two clips, tilt back and I am filling up and it takes about 2 seconds. Very happy with my clip on unit I and I think it looks and performs great. Wolfman explorer lite.
Spec likes this.
2012 Suzuki DL650AL2
1982 BMW R100RT
1985 Diamondback Ascent EX
boatin is offline
Contoured Tank bags for our bikes? Motor7 DL650A - 2012-2016 24 09-18-2018 02:55 AM
Tank Bags for the '14 Strom PhilS14 DL1000A - 2014-2016 32 05-05-2016 12:38 PM
Magnetic Tank bags on V. Marsee 12l expandable KTM Mike General V-Strom Discussion 14 01-23-2014 10:15 AM
Big Magnetic Tank Bags Applepie General V-Strom Discussion 6 04-20-2013 01:39 PM
