Signal Dynamics voltage monitor LED repair - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
  • 1 Post By DesertBike
  • 1 Post By Demache
  • 1 Post By Big B
post #1 of 6 Old 05-10-2019, 01:07 PM Thread Starter
Onboard Mass Damper
DesertBike's Avatar
Almost 3 years ago, I installed a Signal Dynamics Heads Up voltage monitor LED on my 2007 Vee. Whole saga here, if you're bored or need a sleep aid:
https://www.stromtrooper.com/dl1000-...d-install.html
The device has worked perfectly since then...so, of course I had to screw things up by accidentally breaking it.
This likely happened last week, when I was installing a new 12V socket under the cowling. I must have yanked on the wires harder than I realized. A few days ago, I noticed that I was only getting a "blinking green" indication for a few seconds, then nothing, with key turned on but before starting the engine.
If you own one of these things, you'll recognize that this is not normal behavior. What should happen is the LED blinks green, then steady amber, then steady red, as the battery is powering the lights, instrument panel, and fuel pump all by itself. The LED cuts out during actual starting, then stays a steady color (green, if all is normal) with the engine running. Then goes back to amber, then red when you kill the engine but leave the key at run position (in which case, my broken LED is now turning off).
The LED was still showing steady green with the engine running, but I didn't trust it due to the pre-start behavior.
Inspection reveals that I have broken one of the LED's three terminals clean off. There's no way to fix that - it's time for a new LED. No charging system problems. Battery is sitting at a healthy voltage while at rest, charging voltage is right where it should be.
Naturally, the LED's flimsy, plastic panel mount bezel broke in the process of taking it out for the inspection, so I need a replacement for that too.
Here's the happy ending: I called Signal Dynamics, explained the situation and asked for help buying a replacement LED. They're sending out a replacement LED, at no charge, pre-wired and with a new panel mount bezel. Even though it's way out of warranty. I could not ask for better customer service.
I would have happily paid for a replacement LED. But they saved me both $ and effort.
FWIW, if you want to build your own voltage monitor device, don't bother looking for 3-color LEDs that do red, green, and yellow. They seem not to exist, or would be a custom order from an LED manufacturer. I think what Signal Dynamics is actually doing is using a 2-color, red and green LED, mixing red & green modes to make yellow. Which is clever and elegant.
Spec likes this.
2007 Vee with too many farkles
DesertBike is online now
post #2 of 6 Old 05-13-2019, 12:44 PM
Demache's Avatar
Mixing green and red for yellow/orange is very common for indicators that also can be green and red. Its simply easier. Really cool of them to replace it out of warranty though.
DesertBike likes this.
2007 V-Strom DL1000 (current!)
Previous:
1999 Honda Shadow VT1100C (2016-2017)
2003 Yamaha V-Star 650 (2012-2016)
Demache is offline
post #3 of 6 Old 05-13-2019, 01:00 PM Thread Starter
Onboard Mass Damper
DesertBike's Avatar
Yeah, that blew me away. I was prepared to source my own LED and panel bezel, wire it in, the whole works. They'll have saved me considerable effort.
I am contemplating adding one of their flashing brake light doohickeys to my setup. Either just the signal box that modifies the factory brake light, or the full-up deal that adds more lights.
post #4 of 6 Old 05-18-2019, 03:13 PM Thread Starter
Onboard Mass Damper
DesertBike's Avatar
Got the replacement LED, did not get the replacement bezel.
Rather than call Signal Dynamics again and wait another week, I bought a 100-pack of the bezels off Amazon:
https://www.amazon.com/gp/product/B01LX8JVG7/
Can't swear these are the exact ones SD supplies, but they were close enough to do the job.
I thought about upgrading to a metal LED bezel. Still might, but at least now I have something that will work in the interim.
I can live with spending ~$5 to fix things. And now I have tons of spare bezels.
post #5 of 6 Old 05-22-2019, 09:23 PM Thread Starter
Onboard Mass Damper
DesertBike's Avatar
Ugh, this is turning out to be unnecessarily difficult.
Those bezels off Amazon are crap. The legs have no "hook"-ness to them, so they barely hold on to the lip at the bottom of the LED. The slightest touch will push the LED back through the hole.
I guess I'll have to call Signal Dynamics and ask them to pretty please send a replacement bezel or three (as I'm sure I'll break it again if I have to remove the LED for some reason).
post #6 of 6 Old 05-23-2019, 12:06 AM
Can't say I'm a fan of that voltage monitoring system, I had one for a bit and promptly replaced with a waterproof digital unit.
trapperdog likes this.
Signal Dynamics voltage monitor LED install DesertBike DL1000 from 2002-2012 35 01-16-2017 11:38 PM
Everything Related to Tires (Wheel removal, Repairs, DIY, ETC... Skinnifatkid Suspension and Tire Tech 36 10-28-2015 06:23 AM
Updated Turn Signal Post 2presidents DL650 and DL650A - 2004 to 2011 8 02-15-2014 10:51 PM
Signal Dynamics LED Voltage Monitor jamessveta Maintenance, Tech and Products. 4 05-01-2013 08:46 PM
signal dynamics voltage meter Al Gilliland General V-Strom Discussion 6 03-21-2010 01:13 PM
