Cheap & Easy Tutoro Single Nozzle Replacement - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 8Likes
  • 5 Post By Ned
  • 2 Post By George13
  • 1 Post By Ned
post #1 of 5 Old 05-09-2019, 04:05 PM Thread Starter
Ned
I installed a Tutoro Chain Oiler in April 2015 on my Wee and have been very pleased with it. On my first ride this spring I noticed the single nozzle was missing. It appears the short piece of plastic holding the nozzle had gotten brittle with age and the nozzle fell out. Tutoro sells new ends on their site at a reasonable price but I didn't want to wait for shipping from England.
I checked with Richland Rick to see if he had any spare parts (Adventuretech used to be the Tutoro Distributor for the US). He did not have any but suggested looking for parts at a hardware or building supply store. I ran to my local Ace Hardware and purchased a piece of 1/8" hose and a 1/8" Straight Barb Fitting (in the Plumbing area).
I think this will be a great replacement. A quick, cheap and easy fix. If there are any problems with this set up I will post more info.
NOTE: Tutoro has really improved their site in the last couple of years. They added a free downloadable PDF with 48 pages explaining their product, how to install and adjust it, and a trouble shooting guide. Very useful information and is located here.
https://www.tutorochainoiler.com/pag...orkshop-manual
Big B, VSrider, EddieFL and 2 others like this.
Ned is offline
post #2 of 5 Old 05-10-2019, 01:57 PM
OK, so youíre using the barbed fitting as the nozzle, correct? Iíve been trying to find tubing of the correct size to replace the original nozzle. I found some metric tubing online but have to order 50í of it!
Iím gonna try your approach. Thanks!
2015 V-Strom 650XT ABS
1969 Triumph Bonneville
EddieFL is offline
post #3 of 5 Old 05-11-2019, 01:35 AM
I use a plastic tube from a kitchen degreasers spray. Sorry for bad english.
Brockie and EddieFL like this.
George13 is offline
post #4 of 5 Old 05-11-2019, 12:22 PM Thread Starter
Ned
One more thing – Since I lost my Tutoro nozzle due to the plastic tubing getting brittle with age I decided to check all of the tubing. The tube from the reservoir to the Helix section wasn't cracked but was very stiff so I replaced it.
If your Tutoro Oiler has been in use for a few years you should check the tubing.
1/8" plastic tube seemed to work OK, it's very close to 3mm.
EddieFL likes this.
Ned is offline
post #5 of 5 Old 05-11-2019, 06:32 PM
VSrider's Avatar
Great idea. I gave up on nozzles and just have the tubing lightly touching the sprocket. Seems to be working, however the bike I'm riding now has shaft drive.
VSrider is offline
Everything Related to Tires (Wheel removal, Repairs, DIY, ETC... Skinnifatkid Suspension and Tire Tech 36 10-28-2015 06:23 AM
Cheap Replacement for OEM Windscreen. I922sParkCir DL650A - 2012-2016 22 07-27-2013 09:32 PM
Cheap clutch lever replacement?? twopiper General V-Strom Discussion 14 03-08-2008 07:48 AM
Cheap source for OEM Replacement Parts wheelwatcher DL650 and DL650A - 2004 to 2011 3 02-10-2008 09:14 PM
