Switched Power from Flasher Relay - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 2 Old 05-05-2019, 04:36 PM Thread Starter
My 2017 DL650 has a 2 pin flasher relay right behind the battery with a brown wire that appears to be switched 12V. It seems to me this would be a very easy spot to make a little harness with regular spade connectors to tap into the switched 12V to run an aux relay. I cannot however find a single instance where someone else has done this, everyone talks about the tail light wire or the rear brake switch wire which require buying special connectors or cutting wires. Is the flasher configuration different/harder to access on pre 2017 650's and that's why I can't find any info on it? Or is this just a bad place to get switched power for a different reason?
On a side note, the reason I'm doing this is so I can run Oxford heated grips off of a relay. I installed the grips and then didn't ride the bike for a few weeks and found the battery dead. I pulled the fuse for the grips and found they were drawing 50 uA even when off. I'm fairly sure these killed the battery since the bike is brand new, never ridden and this is the only electronic accessory I've installed. I'm in contact with the distributor to find out if this is a normal current draw, or if the controller is faulty. Either way I think I will still run them off of a relay to be safe.
southcppaw is offline
post #2 of 2 Old 05-05-2019, 08:20 PM
Brockie's Avatar
Your bike already has an OEM heated grips connector and I suggest you connect to that for your switched power, then they will only draw power when the ignition is on.
Look through these threads for the connector location plus lots of tips.
https://www.stromtrooper.com/dl650a-...connector.html
https://www.stromtrooper.com/dl650a-...ted-grips.html
Brockie is online now
HOW TO: ABS On/Off Switch brianjonesphoto V-Strom Modifications and Performance 60 09-08-2019 09:35 PM
Heated Gear Relay Schematic nobie381 DL650 and DL650A - 2004 to 2011 16 11-16-2012 11:24 AM
Neutral light power relay danketchpel Maintenance, Tech and Products. 11 10-27-2011 01:12 AM
Reading Wiring Diagrams middie26 General V-Strom Discussion 16 07-20-2011 05:21 PM
new to me bike...is this a relay? is it ready for a power outlet? dieselndixie DL1000 from 2002-2012 7 06-30-2011 12:47 PM
